Connecting a NetComm adsl2+ NB5Plus4W router into a 10/100 wired network
Discussion in 'Networking (Hardware & Software)' started by Codecutter, 2006/01/08.
  1. 2006/01/08
    Codecutter
    Codecutter Inactive Thread Starter
    Connecting a NetComm adsl2+ NB5Plus4W router into a 10/100 wired network.
    I have a Network with a reliable 10/100 wired router which accesses the Net via a Motorola SB4100 cable modem.
    I wish to add wireless capability to the network.
    A friend suggested adding the NetComm NB5Plus4W router.
    Under my current configuration, the ADSL modem would be redundant.
    Has any one any other "best" suggestions for a conversions, which is essentially to expand a wired network, to a combinded wired/wireless network, with VOIP point as a bonus.
    cheers
  2. 2006/01/10
    Go out and get a wireless access point device and hook it to any port on the router via a cat5 cable. Shy away from using the adsl modem-wireless. Linksys makes a couple of access point devices. These devices are just an access point w/ no switch, no router, etc.
    Or you could switch completely to a wireless router that also has wired ports.
