connect pc to the tv via the PCI sound card
Discussion in 'PC Hardware' started by docdoom, 2008/12/15.
  1. 2008/12/15
    docdoom
    docdoom Inactive Thread Starter
    I have an on board sound card and a sound card in one of the P.C.I slots. I have a Sapphire X1650 pro graphics card. My O.S is XP.
    I have connected my pc to my LCD T.V via the DVI port on the graphics card - HDMI port on TV, I also have my monitor connected to the VGA port on this card.
    The sound for my pc comes through the on board sound card to desktop speakers. Which is fine.
    I have a problem in that the graphics card is pre 2000 model so it doesn't support sound through the DVI to HDMI. I have bought a 3.5mm audio lead to connect pc to the tv (via the PCI sound card). I don't want to change the leads from desktop to tv or vice-versa every time I watch a film or switch back to pc. How can I configure this set up?
    Donno if this helps;
    system information>componets>sound devices,
    Name Unimodem Half-Duplex Audio Device
    Manufacturer Microsoft
    Status OK
    PNP Device ID MODEMWAVE\0\{E8C3F2AD-5793-4D3E-A4D4-DA25A115D8AA}
    Driver c:\windows\system32\drivers\modemcsa.sys (5.1.2600.0 (xpclient.010817-1148), 15.75 KB (16,128 bytes), 17/09/2008 16:09)
    -------((I assume this is the on board one))----------
    Name Realtek AC'97 Audio for VIA (R) Audio Controller
    Manufacturer Realtek
    Status OK
    PNP Device ID PCI\VEN_1106&DEV_3059&SUBSYS_73401462&REV_60\3&61AAA01&0&8D
    I/O Port 0x0000E400-0x0000E4FF
    IRQ Channel IRQ 22
    Driver c:\windows\system32\drivers\alcxwdm.sys (5.10.5290, 450.06 KB (460,864 bytes), 16/09/2008 21:39)
    ----------((and this is the PCI card))--------------
  2. 2008/12/16
    I am not certain, but it sounds like you want audio output to the TV when you are doing playback, then change back to PC speakers when you don't.
    Is this what you are looking for?
    http://www.cablestogo.com/product.asp?cat_id=118&sku=40641
    It outputs to both, but will still get output when you want to watch television channels...if so, you might need to get a switch to toggle between the outputs.
    If you have installed the drivers for your PCI card, it probably has the option of running two channels, four channels and maybe 5.1 or 6 channels. You should be able to change the output connectors on the card so that the green connector is for your PC and one of the other two connectors goes to your TV. It will be in the "manager" for the audio card (if you have installed it), there might be an icon in the Notification (System) Tray.
    docdoom
    thanks for the link, I was thinking about using a jack like the one you gave the link for.
