Computers Not Connecting but Ipods do?
Discussion in 'Networking (Hardware & Software)' started by flyboy1565, 2011/02/06.
  1. 2011/02/06
    flyboy1565
    flyboy1565 Inactive Thread Starter
    I am helping a family that has three xp computers wirelessly hooked up to the router, the router works for their ipods but, the computers using a belkin card doen't find the signal. I used the belkin advanced button but all it shows is a ping testy that passes a loopback but not ip,gateway, dns, wan, heartbeat,belkin,yahoo.
    Lol I' m good with virus removal now... but this has me a little stumped.
    Any help will do thanks,
    flyboy1565
  2. 2011/02/07
    On XP, dump the Belkin connection utility and "let Windows manage the wifi connection. "
    flyboy1565
    i tried to use windows for that but the belkin doesn't allow the change. I tried to uninstall the belkin with no response.
  5. 2011/02/08
    Run this command from a command prompt cmd /c ipconfig /all>%temp%\$.$&notepad %temp%\$.$
    Copy/paste the output in your next reply.
    There will be a setting in the Belkin software for it.
  7. 2011/02/08
    flyboy1565
    ok i'll try in a day or two, thanks
