Compatibility Issue MS Works/XP
Discussion in 'Other PC Software' started by Rich D, 2004/07/27.
  1. 2004/07/27
    Rich D
    Rich D Inactive Thread Starter
    Hi Folks
    Just trying to help someone out myself and im relying on you guys/gals to help me now ! :(
    He has used MS Works 3.0 on an old Windows 95 based machine for years and has loads of .wps files that he would like to be able to open on a Dell XP based new computer.
    Trouble is i cannot get MS Works 3.0 to run on XP even when using the compatibility wizard for 95 / 98 etc
    The program loads up fine but the egg timer is continuosly shown upon opening a .wps file previously created.
    Although he has gone over to Office XP, is there any way of getting MS Works 3.0 to run or is it a case of having to purchase MS Works 7.0 to be able to read old .wps files?
    Many thanks as ever
    Richard
  2. 2004/07/27
    Richard
    *.wps files open fine in Word 2003 (not sure which version of Works they were created in, but file date is 1997) - have you tried simply 'Open With' and selecting Word?
    Rich D
    Thanks Pete i didnt even consider trying that one ! DOH !
    Seems like your week isnt so bad after all, that works fine. Many thanks for your help !
  5. 2004/07/27
    You're welcome - yes, it is improving :)
