Resolved Command Shell Not Recognizing Commands
Discussion in 'Windows XP' started by Lydeard, 2011/10/25.
  1. 2011/10/25
    Lydeard
    Lydeard Well-Known Member Thread Starter
    XP Pro SP3
    I have a couple of minor issues which I am trying to resolve which are on another post, but when trying to work through the suggestions kind people have offered there I need to use use the CMD function in the Command Shell but can't get it to work (it used to in the past).
    The message I get when entering a command eg. 'IPConfig', 'Ping' or any others as far as I can see is;
    ''IPConfig' is not recognized as an internal or external command, operable program or batch file'.
    Searching for possible reasons for this (Google etc) most people reckon it is likely to be a 'Path' problem or corruption but I need a bit of help in checking and, if necessary, correcting this.
    If I go to 'System Properties>Advanced>Environment Variables' and look at the Path in the System Variables I see;
    C:\WINDOWS\System32;C\WINDOWS;..
    If I highlight this to Edit it I get the Variable Value shown as;
    %SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\wbem
    Is this all as should be ?. If it is then what else is the possible cause of the commands not being recognized ?.
    Would greatly appreciate some help.
  2. 2011/10/25
    What happens/shows when you type path in the command window (& press Enter)?
    Lydeard
    I get:-
    Path = %SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\wbem
  5. 2011/10/25
    That's not good :(
    You should get:
    Are you logged into an Administrator account?
    Try creating a new account & see if that works.
    Lydeard likes this.
  6. 2011/10/25
    Lydeard
    Yes Arie I am sole 'Owner/Administrater.
    So sorry to be a 'pain' but how do I create a new account ? Do you mean User Account, if you do then I think I can do that.
  7. 2011/10/25
    Yea, sorry, I meant user account :)
    Lydeard likes this.
  8. 2011/10/26
    Lydeard
    You're a star Arie, changed the Path to the value you said it should be and all seems to be well with the Command Shell now, didn't need to create a new user account. Thank you so much. I can get back to original problem and my thread about IPSec Services now.
    I wonder what caused the Path to become corrupted, the Command Shell used to be working ok.
    Regards
    Graham
