come in,help me,question of IE homepage!
Discussion in 'Security and Privacy' started by magicsolo, 2004/08/07.
  1. 2004/08/07
    magicsolo
    magicsolo Inactive Thread Starter
    :confused: What I used is WIN2000, my IE homepage is a website that I do not know all the time, after revise in internet attribute each time, the situation is the same after restarting.
    what shall I do?
    Pls help!
  2. 2004/08/07
    24jedi Lifetime Subscription
    24jedi Well-Known Member
    sounds like you have an entry in the registry.
    each time you restart your workstation, no matter what you saved prior to restart, some other website is shown.
    At the top of this forum is two Pinned forum threads. These threads deal with Virus / Torjans / and hacks. What it sounds like you have is a hack. Basically, you went to some website in the past that automatically changed your homepage and saved that website to some attribute in the registry. Until you remove this fom the registry, it's not going away...at a minimum.
    Review the above links for additional troubleshooting. Specifically Ad-ware and hijackthis are the niformation you should review.
    magicsolo,
    It sounds like your Home Page has been Hijacked.
    Download Ad-aware and Spybot through Quicklinks in my signature and immediately update both. Configure Ad-aware for a full Scan as outlined below ....
    How to Perform a "˜Full Scan’ with Ad-aware 6 build 181
    In Ad-aware click the Gear to go to the Settings area.
    The following items should be on a green check, not on a red x
    Under the Scanning Button "¦.
    Scan within archives
    Under Memory and Registry, check EVERYTHING
    In Check Drives and Folders, make sure all of your hard drives are selected
    Under the Advanced Button "¦.
    Check all under Log detail level
    Under the Tweak Buttons "¦.
    Some of these may not be an option depending on your version of Ad-aware and your version of Windows. Do not be concerned if you cannot select a certain item.
    In Scanning Engine "¦.
    Unload recognised processes during scanning
    Include info about ignored objects in log file, if detected in scan
    Include basic Ad-aware settings in log file
    Include additional Ad-aware settings in log file
    Include used command line parameters in log file
    In Cleaning Engine "¦.
    XP/2000: Allow unloading explorer to unload shell extensions prior to deletion
    Let Windows remove files in use at next reboot
    UNCHECK: Automatically try to unregister objects prior to deletion
    Click Proceed to save these settings, When you would like to perform a "˜Full Scan’, switch the scan mode from SmartScan to Custom.
    Run Ad-aware and Spybot - delete all Ad-aware finds ans all items in red that Spybot finds (green items are usage tracks, deletion optional.
    Then download HijackThis, save it to a folder on your hard drive, unzip it and run it, Save the log file and copy and paste it here. Fix nothing - wait for instructions from those familiar with analysing these logs
    And finally ....
    Please do not post in Bold on the Board
  5. 2004/08/09
    magicsolo
    Thank you for PeterC's help, I download ad-aware and hijackthis,have succeeded in solving the problem. :rolleyes:
  6. 2004/08/09
    Glad to hear your problem is solved - good idea to run Ad-aware and Spybot regularly.
    Give yourself another level of permanent protection - in Spybot click on the imminize icon and again on the imunize green + icon.
