cmos battery replacement
Discussion in 'PC Hardware' started by bentenmen, 2008/12/12.
  1. 2008/12/12
    bentenmen
    bentenmen Inactive Thread Starter
    my laptop reports cmos power low, I have to press F1 to enter set up and enter date and time, I eventually decided to replace the cmos cell battery, checked ID and replaced with new battery. Result power on then powers down straight away, when i put old battery back in revert to entering set up once again but am able to use laptop. tried a another new battery with same result. laptop will not power up without old battery in place , any ideas?
    thanks
  2. 2008/12/12
    wildfire
    wildfire Getting Old
    Try this (it's amazing how often it works) ;)
    Use your new CMOS Battery
    Disconnect both PSU and Main Battery
    Press and hold the power switch for 30 seconds.
    Reconnect the main battery and PSU if required
    Switch on.
    Let us know if that works
    bentenmen
    wildfire
    thanks a bundle that seems to have worked great
    now going straight to xp start up
    thanks again for your input
    bentenmen
  5. 2008/12/12
    wildfire
    No problem, happy to help.
