Closing 1 window closes all + IE has encountered a problem
Discussion in 'Internet Explorer & Microsoft Edge' started by padcaz123, 2007/05/20.
  1. 2007/05/20
    padcaz123
    padcaz123 Inactive Thread Starter
    Can anyone help me please
    everytime i open 2 windows in explorer and shut 1 down it shuts both what can i do please. TA
    A message appears stating that Explorer has encountered a problem.
    Have i got my settings wrong
    Thanks in advance:
    Jason
  2. 2007/05/20
    Paul
    Paul Inactive
    Paul,
    padcaz123
    Internet Explorer has stopped working
    Hi pete
    thanks for your response, here is the error log that explorer gives me, any ideas would be greatly appreciated
    Ta
    Jason
    Problem signature:
    Problem Event Name: APPCRASH
    Application Name: iexplore.exe
    Application Version: 7.0.6000.16386
    Application Timestamp: 4549b133
    Fault Module Name: kernel32.dll
    Fault Module Version: 6.0.6000.16386
    Fault Module Timestamp: 4549bd80
    Exception Code: 800401fd
    Exception Offset: 0001b09e
    OS Version: 6.0.6000.2.0.0.768.3
    Locale ID: 2057
    Additional Information 1: 8d13
    Additional Information 2: cdca9b1d21d12b77d84f02df48e34311
    Additional Information 3: 8d13
    Additional Information 4: cdca9b1d21d12b77d84f02df48e34311
  6. 2007/05/23
    Unfortunately the error log is of little use stating merely that Internet Explorer crashed, but it does show that you are running IE 7
    The first action I would suggest is to disable all Explorer Add-ons ....
    Tools > Manage Add-ons > Enable or Disable Add-ons.
    Disable all the add-ons - if the problem is resolved restore them one by one until the problem reoccurs - you have then found the culprit :)
    If you are running the Yahoo Toolbar I suggest you uninstall it for the time being - this could also be the cause of your problem.
