Resolved Cloning XP Home To A Network Drive
Discussion in 'Networking (Hardware & Software)' started by James Martin, 2010/07/08.
  1. 2010/07/08
    James Martin
    James Martin Geek Member Thread Starter
    Is this possible?
    My brother wants me to install a new HD on his PC, but he has room for only one drive. I told him to buy an external enclosure and clone the drive that way, but he doesn't want to buy one right now, so I was thinking about making his new drive a network drive in my machine, and cloning his old one over to it via network connections.
  2. 2010/07/08
    Depends on what program you are using to clone the drive.
    It would be better if you could connect BOTH his drive in your computer & then clone the old drive. It would be much faster & almost every cloning util [even free ones] would do the job.
    Agree with rsinfo - no need to fit the drive into the computer, just connect it up loose, BUT you do not state if the PC concerned is a laptop or desktop. Simple on a desktop, not so on a laptop.
  5. 2010/07/08
    James Martin
    On second thought I'll have to scratch the idea.
    I went brain dead and forgot his drives are SATA, and mine are PATA. In addition, my board will not support anything over 160gb (his new drive is 250gb). :rolleyes:
    I guess my only option is to clone XP Home via the already mentioned external drive kit, or just re-install the OS (Fun! :eek:) after I install the replacement drive.
  6. 2010/07/08
    A fresh install is always preferable as you get rid of many problems in the old setup.
  7. 2010/07/10
    James Martin
    I installed the new Seagate hard-drive with no issues, and I am now installing XP Home updates, along with 3rd party software.
    In addition, I replaced the old memory (2 banks of 256mb) with 2 banks 512mb from Crucial...
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820146521
    Everest say's the memory timings have jumped up a notch to
    *333MHz 5.0-5-5-15
    *266MHz 4.0-4-4-12
    *200MHz 3.0-3-3-9
    The old memory readings never went over 266MHz.
    What do these readings mean? Which setting does the new memory use, or does it use all three at various times?
    Edit: Link to new drive...
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822148451
  8. 2010/07/15
    Your new memory has extended capability and will run at the highest frequency that the motherboard will accept.
  9. 2010/07/15
    James Martin
    Right off hand I don't remember how to check the current memory frequency. I assume the BIOS would tell me, but I never saw a way to manually change the clock speed...which is something I don't do anyway.
    I was contemplating re-installing the old RAM, along with the new, but I don't want to dumb the system down any. I've yet to see this machine use much over 50 percent of its current memory capacity.
  10. 2010/07/15
    You can mix the old & new RAM provided the board supports it. However, the system would use the lowest specifications of either RAM. In your case it would be 266 MHz.
