Clicking on URL's won't work
Discussion in 'Internet Explorer & Microsoft Edge' started by Angel, 2003/04/19.
  1. 2003/04/19
    Angel
    Angel Inactive Thread Starter
    When I click on a URL in an email message it won't work. I have to copy and paste it to Internet Explorer! It used to work but now it doesn't. Help Please.:confused:
  2. 2003/04/19
    Miz
    Miz Inactive Alumni
    Abraxas
    Abraxas Inactive
    Start > Run:
    regsvr32 urlmon.dll
  5. 2003/04/19
    Angel
    URL Links Don't Work in Outlook Express
    Well I tried all of the above but no change, The links when I click on them still don't work. It looks like it will ie the cursor changes to the hand, but nothing happens. Any more ideas most welcome.:confused:
  6. 2003/04/19
    brett
    brett Inactive Alumni
    aleekat
    aleekat Inactive
    I have to ask the obvious. Do you have a popup killer installed?
  8. 2003/04/19
    Angel
    No I don't have a Pop up killer installed. I am using IE 6, do you think I should try a reinstall? Thanks for your help, all suggestions appreciated.:(
  9. 2003/04/19
    Miz
    Miz Inactive Alumni
    The only other thing I can think of is in Internet Explorer, go to Tools>Internet Options>Programs tab and make sure Outlook Express in is the Email field.
    Miz,
    #8
  10. 2003/04/20
    Abraxas
    Abraxas Inactive
    What OS are you running? You may be able to do a repair if redownloading it is not to your liking (you may end up doing that anyway).
    This patch from Microsoft addresses a different problem but it replaces urlmon.dll with an updated version (you may already have it from Windows Update). Worth a try. Can't hurt.
    http://www.microsoft.com/windows/ie/downloads/critical/813951/default.asp
  11. 2003/04/20
    Angel
    Yes Outlook Express is there in Internet Options. I have Windows XP Professional installed.
  12. 2003/04/21
    Angel
    Ok everyone, I have fixed it I think!! I did a system restore, back to 2 weeks ago and it is now working, I would like to know what the gemlin was though, but maybe never will. Thanks for your help. Much appreciated. :)
