civsc.exe problem
Discussion in 'Malware and Virus Removal Archive' started by madman, 2006/06/26.
  1. 2006/06/26
    madman
    madman Inactive Thread Starter
    hi there. I've recently noticed that a file called civsc.exe is eating up a lot of my processing power. Sometimes it gets as high as 90%. I googled it and apparently it's a spyware file. Is this true? I routinely run Spybot, Adaware and Ewido, and none of them have detected it. How can I get rid of it?
  2. 2006/06/26
    TeMerc
    TeMerc Inactive Alumni
    Hi Madman and welcom.
    That file is related to an rbot worm. Have you run any av scans? If not i would do so. I'd also grab an online scan as well:
    TrendMicroâ„¢ HouseCall Java Scan
    • Please go HERE to run the Trend Microâ„¢ HouseCall Scan.
    • Click Scan now. It's free!
    • Read and put a Check next to Yes I accept the terms of use.
    • Click the Launching HouseCall>> button.
    • If confirmed that HouseCall can run on your system, under Using Java-based HouseCall kernel click the Starting HouseCall>> button.
    • You may receive a Security Warning about the TrendMicro Java applet, click YES.
    • Under Scan complete computer for malware, grayware, and vulnerabilities click the Next>> button.
    • Please be patient while it installs, updates, and scans your system.
    • Once the scan is complete, it will take you to the summary page.
    • Under Cleanup options, choose clean all detected infections automatically.
    • Click the Clean now>> button.
    • If anything was found you may be prompted to run the scan again, you can just close the browser window.
    I would also as if you used the latest Ewido anti-spyware, s the app was just uipdated last week.
    Once you have run the Trend Micro scan, please post a Hijackthis log file for us to examine.
    Use HiJackThis v:1.99.1zip.
    DL the zip file to your desktop, then create a new folder on your C drive, called 'HJT' or 'HijackThis'. Then unzip the files to the new folder. When you run HijackThis.exe from C:\HJT folder and have it "Fixed checked" it will create a backup file of modifications to use if restore is necessary which is easily accessible.
    Run the program, and press Scan. You will notice the Scan button will turn into a "Save Log" button. Save the log and Post that log onto this topic. DO NOT DELETE or modify anything yet, as some of it is needed to keep your system in proper working order.
    madman
    hjt log
    hey there. The trend micro scan found a few things, and cleaned them I assume. Right now my biggest problem is that whenever I run more than a couple of programs the explorer.exe process suddenly uses up 100% of my cpu and everything goes very slow. I thought maybe it was overheating cos I use it all day and my brother uses it all night, but I guess not. Here's my hjt log...
    Logfile of HijackThis v1.99.1
    Scan saved at 10:13:49 AM, on 27/06/2006
    MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
    C:\Program Files\Ahead\InCD\InCDsrv.exe
    F:\Program Files\avast\aswUpdSv.exe
    F:\Program Files\avast\ashServ.exe
    C:\WINDOWS\system32\cisvc.exe
    C:\WINDOWS\system32\CTsvcCDA.EXE
    C:\Program Files\ewido\security suite\ewidoctrl.exe
    C:\WINDOWS\system32\nvsvc32.exe
    C:\Program Files\Common Files\Symantec Shared\SNDSrvc.exe
    C:\WINDOWS\system32\ZoneLabs\vsmon.exe
    C:\WINDOWS\system32\fxssvc.exe
    F:\Program Files\avast\ashMaiSv.exe
    F:\Program Files\avast\ashWebSv.exe
    C:\Program Files\ScanSoft\OmniPageSE2.0\OpwareSE2.exe
    C:\Program Files\NVIDIA Corporation\NvMixer\NVMixerTray.exe
    C:\Program Files\Microsoft Hardware\Keyboard\type32.exe
    C:\WINDOWS\system32\RunDLL32.exe
    F:\PROGRA~1\avast\ashDisp.exe
    C:\Program Files\Zone Labs\ZoneAlarm\zlclient.exe
    C:\Program Files\Creative\MediaSource\Detector\CTDetect.exe
    C:\WINDOWS\system32\rundll32.exe
    C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
    C:\Program Files\SilentTek\HardwareMonitor.exe
    C:\Program Files\Mozilla Firefox\firefox.exe
    C:\hjt\HijackThis.exe
    R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyServer = library.ubc.ca:8000
    O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
    O2 - BHO: (no name) - {206E52E0-D52E-11D4-AD54-0000E86C26F6} - (no file)
    O4 - HKLM\..\Run: [OpwareSE2] "C:\Program Files\ScanSoft\OmniPageSE2.0\OpwareSE2.exe "
    O4 - HKLM\..\Run: [NVMixerTray] "C:\Program Files\NVIDIA Corporation\NvMixer\NVMixerTray.exe "
    O4 - HKLM\..\Run: [IntelliType] "C:\Program Files\Microsoft Hardware\Keyboard\type32.exe "
    O4 - HKLM\..\Run: [IMJPMIG8.1] C:\WINDOWS\IME\imjp8_1\IMJPMIG.EXE /Spoil /RemAdvDef /Migration32
    O4 - HKLM\..\Run: [imjpmig] C:\IME\IMJP\imjpmig.exe /RemAdvDef /AIMEREG /Migration /SetPreload
    O4 - HKLM\..\Run: [HardwareMonitor] C:\Program Files\SilentTek\RegInformation.exe
    O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
    O4 - HKLM\..\Run: [nwiz] nwiz.exe /install
    O4 - HKLM\..\Run: [NvMediaCenter] RunDLL32.exe NvMCTray.dll,NvTaskbarInit
    O4 - HKLM\..\Run: [iTunesHelper] "C:\Program Files\iTunes\iTunesHelper.exe "
    O4 - HKLM\..\Run: [avast!] F:\PROGRA~1\avast\ashDisp.exe
    O4 - HKLM\..\Run: [REGSHAVE] C:\Program Files\REGSHAVE\REGSHAVE.EXE /AUTORUN
    O4 - HKLM\..\Run: [Zone Labs Client] "C:\Program Files\Zone Labs\ZoneAlarm\zlclient.exe "
    O4 - HKCU\..\Run: [Creative Detector] C:\Program Files\Creative\MediaSource\Detector\CTDetect.exe /R
    O4 - HKCU\..\Run: [SpybotSD TeaTimer] C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
    O4 - HKCU\..\Run: [msnmsgr] "C:\Program Files\MSN Messenger\msnmsgr.exe" /background
    O4 - Startup: Shortcut to Free Sticky Notes.LNK.disabled
    O4 - Global Startup: Adobe Reader Speed Launch.lnk = C:\Program Files\Adobe\Acrobat 7.0\Reader\reader_sl.exe
    O4 - Global Startup: Adobe Reader Speed Launch.lnk.disabled
    O6 - HKCU\Software\Policies\Microsoft\Internet Explorer\Restrictions present
    O6 - HKCU\Software\Policies\Microsoft\Internet Explorer\Control Panel present
    O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
    O16 - DPF: Yahoo! Chat -
    O16 - DPF: {08B0E5C0-4FCB-11CF-AAA5-00401C608500} -
    O16 - DPF: {17492023-C23A-453E-A040-C7C580BBF700} (Windows Genuine Advantage Validation Tool) - http://go.microsoft.com/fwlink/?linkid=39204
    O16 - DPF: {2B323CD9-50E3-11D3-9466-00A0C9700498} (Yahoo! Audio Conferencing) - http://us.chat1.yimg.com/us.yimg.com/i/chat/applet/v45/yacscom.cab
    O16 - DPF: {31E68DE2-5548-4B23-88F0-C51E6A0F695E} (Microsoft PID Sniffer) - https://support.microsoft.com/OAS/ActiveX/odc.cab
    O16 - DPF: {41F17733-B041-4099-A042-B518BB6A408C} -
    O16 - DPF: {56336BCB-3D8A-11D6-A00B-0050DA18DE71} -
    O16 - DPF: {74D05D43-3236-11D4-BDCD-00C04F9A3B61} (HouseCall Control) - http://a840.g.akamai.net/7/840/537/2004061001/housecall.trendmicro.com/housecall/xscan53.cab
    O16 - DPF: {7F8C8173-AD80-4807-AA75-5672F22B4582} (ICSScanner Class) - http://download.zonelabs.com/bin/promotions/spywaredetector/ICSScanner.cab
    O16 - DPF: {90C9629E-CD32-11D3-BBFB-00105A1F0D68} -
    O16 - DPF: {AB29A544-D6B4-4E36-A1F8-D3E34FC7B00A} -
    O16 - DPF: {B942A249-D1E7-4C11-98AE-FCB76B08747F} -
    O16 - DPF: {EB387D2F-E27B-4D36-979E-847D1036C65D} (QDiagHUpdateObj Class) - http://h30043.www3.hp.com/hpdj/en/check/qdiagh.cab?312
    O16 - DPF: {EF791A6B-FC12-4C68-99EF-FB9E207A39E6} (McFreeScan Class) - http://download.mcafee.com/molbin/iss-loc/vso/en-us/tools/mcfscan/1,5,0,4307/mcfscan.cab
    O18 - Protocol: msnim - {828030A1-22C1-4009-854F-8E305202313F} - "C:\PROGRA~1\MSNMES~1\msgrapp.dll" (file missing)
    O20 - Winlogon Notify: WgaLogon - C:\WINDOWS\SYSTEM32\WgaLogon.dll
    O23 - Service: avast! iAVS4 Control Service (aswUpdSv) - Unknown owner - F:\Program Files\avast\aswUpdSv.exe
    O23 - Service: avast! Antivirus - Unknown owner - F:\Program Files\avast\ashServ.exe
    O23 - Service: avast! Mail Scanner - Unknown owner - F:\Program Files\avast\ashMaiSv.exe" /service (file missing)
    O23 - Service: avast! Web Scanner - Unknown owner - F:\Program Files\avast\ashWebSv.exe" /service (file missing)
    O23 - Service: Creative Service for CDROM Access - Creative Technology Ltd - C:\WINDOWS\system32\CTsvcCDA.EXE
    O23 - Service: ewido security suite control - ewido networks - C:\Program Files\ewido\security suite\ewidoctrl.exe
    O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
    O23 - Service: InCD Helper (InCDsrv) - Nero AG - C:\Program Files\Ahead\InCD\InCDsrv.exe
    O23 - Service: iPodService - Apple Computer, Inc. - C:\Program Files\iPod\bin\iPodService.exe
    O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\system32\nvsvc32.exe
    O23 - Service: Remote Packet Capture Protocol v.0 (experimental) (rpcapd) - Unknown owner - %ProgramFiles%\WinPcap\rpcapd.exe" -d -f "%ProgramFiles%\WinPcap\rpcapd.ini (file missing)
    O23 - Service: Symantec Network Drivers Service (SNDSrvc) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\SNDSrvc.exe
    O23 - Service: TrueVector Internet Monitor (vsmon) - Zone Labs, LLC - C:\WINDOWS\system32\ZoneLabs\vsmon.exe
  5. 2006/06/27
    TeMerc
    Ok, I don't see anything in your log. what was it that House call removed?
    did you also run Ewido again, and if so what were the results?
    Another thing you can try is disabling some things you have running, not all of them are needed.
    Here is an excellent site for that:
    AnswersThatWork
    Just go to the appropriate letter, and search for the process/exe, they will give good detailed info regarding it, we use it quite often.
    Let me know about the other things.
