choices when starting xp
Discussion in 'Windows XP' started by tdmai74, 2002/09/18.
  1. 2002/09/18
    tdmai74
    tdmai74 Inactive Thread Starter
    hello, i just upgraded from win 2k to xp and everything works great except when i restart the computer it gives me te option of starting 2k or xp. I would rather it just start xp automatically. any suggestions.....thank you
  2. 2002/09/18
    If you upgraded (replaced 2K with XP) just edit the boot.ini file in c:\ and remove the 2K entry. Regular text file so notepad, edit, or any similar will deal with it fine. DO NOT use a word processor for the job though.
    If you set up to dual-boot, set XP as the default and lower the time from the default of 30 seconds to 5 or so and you won't have so long to wait for XP to start up.
