Solved Checking my pc for problems.
Discussion in 'Malware and Virus Removal Archive' started by Forsaken Knight, 2011/10/26.
  1. 2011/10/26
    Forsaken Knight
    Forsaken Knight Well-Known Member Thread Starter
    [Resolved] Checking my pc for problems.
    1. Just here to make sure my pc is running well as it should be.
    2. I tried updating malwarebytes, but the program ran into an error. I took a screen shot of this. I could not run the program with out updating as well.
    3. aswMBR.exe did not run completely. I ran it, and it kept getting stalled. I took screen shots of this.
    4. I would also like to check to see if flash player can be fixed. I constantly have videos stop on me, such as those on www.youtube.com and such. I can stop the download of the video and start it up again, but the problem of the video not playing smoothly, and in constant loop after a few seconds of starting, persists.
    5. The following are screen shots of the problems when I tried updating windows, and tried running the initial scans required for malware removal forums section.
    Uploaded with ImageShack.us
    6. Each time I clicked on to download or run one of the programs, IE gave me the warning that the license couldn't be confirmed. So, after noticing that IE didn't let me run the malwarebytes program after I tried downloading it, I decided just to run the other programs instead of downloading then running them.
    7. I would like to know what I may to in order to fix my laptop pc.
    Thank you for your time, I look forward to hearing a response.
    Sincerely,
    FK
  2. 2011/10/26
    Forsaken Knight
    GMER 1.0.15.15641 - http://www.gmer.net
    Rootkit scan 2011-10-26 17:07:15
    Windows 6.1.7601 Service Pack 1
    Running: myrfy9o3.exe
    ---- Files - GMER 1.0.15 ----
    File C:\Windows\Temp\TMP0000001993D39CB552047BFA 0 bytes
    ---- EOF - GMER 1.0.15 ----
    Forsaken Knight
    DDS (Ver_2011-08-26.01) - NTFSAMD64
    Internet Explorer: 9.0.8112.16421 BrowserJavaVersion: 1.6.0_26
    Run by walmart at 17:36:51 on 2011-10-26
    Microsoft Windows 7 Home Premium 6.1.7601.1.1252.1.1033.18.3002.1499 [GMT -4:00]
    AV: avast! Antivirus *Enabled/Updated* {2B2D1395-420B-D5C9-657E-930FE358FC3C}
    SP: avast! Antivirus *Enabled/Updated* {904CF271-6431-DA47-5FCE-A87D98DFB681}
    SP: Windows Defender *Enabled/Updated* {D68DDC3A-831F-4fae-9E44-DA132C1ACF46}
    FW: ZoneAlarm Firewall *Enabled* {D17DF357-CFF5-F001-D1C1-FCD21DFE3D5E}
    C:\Windows\system32\wininit.exe
    C:\Windows\system32\lsm.exe
    C:\Windows\system32\svchost.exe -k DcomLaunch
    C:\Windows\system32\svchost.exe -k RPCSS
    C:\Windows\System32\svchost.exe -k LocalServiceNetworkRestricted
    C:\Windows\System32\svchost.exe -k LocalSystemNetworkRestricted
    C:\Windows\system32\svchost.exe -k netsvcs
    C:\Windows\system32\svchost.exe -k LocalService
    C:\Windows\system32\svchost.exe -k NetworkService
    C:\Windows\SysWOW64\ZoneLabs\vsmon.exe
    C:\Windows\system32\Dwm.exe
    C:\Windows\Explorer.EXE
    C:\Windows\system32\WLANExt.exe
    C:\Windows\system32\conhost.exe
    C:\Program Files\Alwil Software\Avast5\AvastSvc.exe
    C:\Program Files\CheckPoint\ZAForceField\IswSvc.exe
    C:\Program Files (x86)\Intel\Intel Matrix Storage Manager\IAAnotif.exe
    C:\Program Files\Realtek\Audio\HDA\RAVCpl64.exe
    C:\Program Files\eMachines\eMachines Power Management\ePowerTray.exe
    C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
    C:\Program Files\Microsoft IntelliPoint\ipoint.exe
    C:\Windows\System32\hkcmd.exe
    C:\Windows\System32\igfxpers.exe
    C:\Program Files\Saitek\SD6\Software\ProfilerU.exe
    C:\Program Files\Saitek\SD6\Software\SaiMfd.exe
    C:\Program Files (x86)\FileHippo.com\UpdateChecker.exe
    C:\Program Files (x86)\McAfee Security Scan\2.1.121\SSScheduler.exe
    C:\Program Files (x86)\Secunia\PSI\psi_tray.exe
    C:\Program Files\Alwil Software\Avast5\AvastUI.exe
    C:\Windows\system32\igfxsrvc.exe
    C:\Program Files (x86)\OpenOffice.org 3\program\soffice.exe
    C:\Program Files (x86)\OpenOffice.org 3\program\soffice.bin
    C:\Windows\System32\spoolsv.exe
    C:\Windows\system32\taskhost.exe
    C:\Windows\system32\svchost.exe -k LocalServiceNoNetwork
    C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe
    C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
    C:\Program Files (x86)\Bonjour\mDNSResponder.exe
    C:\Program Files\eMachines\eMachines Power Management\ePowerSvc.exe
    C:\Program Files (x86)\eMachines\Registration\GregHSRW.exe
    C:\Program Files (x86)\NewTech Infosystems\NTI Backup Now 5\SchedulerSvc.exe
    C:\Program Files (x86)\Secunia\PSI\PSIA.exe
    C:\Program Files\eMachines\eMachines Updater\UpdaterService.exe
    C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVC.EXE
    C:\Program Files (x86)\Intel\Intel Matrix Storage Manager\IAANTMon.exe
    C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSvcM.exe
    C:\Windows\system32\svchost.exe -k LocalServiceAndNoImpersonation
    C:\Windows\system32\SearchIndexer.exe
    C:\Windows\system32\svchost.exe -k NetworkServiceNetworkRestricted
    C:\Program Files (x86)\Secunia\PSI\sua.exe
    C:\Program Files (x86)\Launch Manager\LManager.exe
    C:\Program Files\Synaptics\SynTP\SynTPHelper.exe
    C:\Program Files (x86)\Zone Labs\ZoneAlarm\zlclient.exe
    C:\Program Files (x86)\iTunes\iTunesHelper.exe
    C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe
    C:\Windows\system32\igfxext.exe
    C:\Windows\system32\wbem\unsecapp.exe
    C:\Program Files\Windows Media Player\wmpnetwk.exe
    C:\Windows\System32\svchost.exe -k LocalServicePeerNet
    C:\Program Files\CheckPoint\ZAForceField\ForceField.exe
    C:\Windows\system32\wbem\wmiprvse.exe
    C:\Program Files\eMachines\eMachines Power Management\ePowerEvent.exe
    C:\Program Files (x86)\Internet Explorer\iexplore.exe
    C:\Program Files (x86)\Google\Google Toolbar\GoogleToolbarUser_32.exe
    C:\Windows\System32\svchost.exe -k secsvcs
    C:\Windows\system32\svchost.exe -k SDRSVC
    C:\Windows\System32\taskmgr.exe
    C:\Windows\system32\SearchProtocolHost.exe
    C:\Windows\system32\SearchFilterHost.exe
    C:\Windows\SysWOW64\cmd.exe
    C:\Windows\SysWOW64\cscript.exe
    uStart Page = hxxp://www.google.com/webhp?sourceid=navclient&ie=UTF-8&rlz=1T4ACEW_enUS368US370
    mStart Page = hxxp://homepage.emachines.com/rdr.aspx?b=ACEW&l=0409&m=e725&r=273603108715l04f4z1m5r4422023o
    uInternet Settings,ProxyOverride = *.local
    uURLSearchHooks: ZoneAlarm Toolbar: {66f2e20d-0da8-4c11-a9c8-dd8477b88acd} - C:\Program Files (x86)\ZoneAlarm\tbZone.dll
    uURLSearchHooks: FCToolbarURLSearchHook Class: {868978c8-95f3-4020-a5cd-5a16d60e36ca} - C:\Program Files (x86)\Dividend Miles Toolbar\Helper.dll
    uURLSearchHooks: H - No File
    mURLSearchHooks: ZoneAlarm Toolbar: {66f2e20d-0da8-4c11-a9c8-dd8477b88acd} - C:\Program Files (x86)\ZoneAlarm\tbZone.dll
    BHO: Adobe PDF Link Helper: {18df081c-e8ad-4283-a596-fa578c2ebdc3} - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
    BHO: ZoneAlarm Toolbar: {66f2e20d-0da8-4c11-a9c8-dd8477b88acd} - C:\Program Files (x86)\ZoneAlarm\tbZone.dll
    BHO: Dividend Miles Toolbar BHO: {69cd690c-70b1-4333-ad69-28fff7118c56} - C:\Program Files (x86)\Dividend Miles Toolbar\Toolbar.dll
    BHO: ZoneAlarm Security Engine Registrar: {8a4a36c2-0535-4d2c-bd3d-496cb7eed6e3} - C:\Program Files\CheckPoint\ZAForceField\WOW64\TrustChecker\bin\TrustCheckerIEPlugin.dll
    BHO: Windows Live ID Sign-in Helper: {9030d464-4c02-4abf-8ecc-5164760863c6} - C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
    BHO: Windows Live Messenger Companion Helper: {9fdde16b-836f-4806-ab1f-1455cbeff289} - C:\Program Files (x86)\Windows Live\Companion\companioncore.dll
    BHO: Google Toolbar Helper: {aa58ed58-01dd-4d91-8333-cf10577473f7} - C:\Program Files (x86)\Google\Google Toolbar\GoogleToolbar_32.dll
    BHO: WOT Helper: {c920e44a-7f78-4e64-bdd7-a57026e7feb7} - C:\Program Files (x86)\WOT\WOT.dll
    BHO: Java(tm) Plug-In 2 SSV Helper: {dbc80044-a445-435b-bc74-9c25c1c588a9} - C:\Program Files (x86)\Java\jre6\bin\jp2ssv.dll
    TB: ZoneAlarm Security Engine: {ee2ac4e5-b0b0-4ec6-88a9-bca1a32ab107} - C:\Program Files\CheckPoint\ZAForceField\WOW64\TrustChecker\bin\TrustCheckerIEPlugin.dll
    TB: ZoneAlarm Toolbar: {66f2e20d-0da8-4c11-a9c8-dd8477b88acd} - C:\Program Files (x86)\ZoneAlarm\tbZone.dll
    TB: Dividend Miles Toolbar: {3948072d-28fe-4206-9f7f-2aff92b24679} - C:\Program Files (x86)\Dividend Miles Toolbar\Toolbar.dll
    TB: WOT: {71576546-354d-41c9-aae8-31f2ec22bf0d} - C:\Program Files (x86)\WOT\WOT.dll
    TB: Google Toolbar: {2318c2b1-4965-11d4-9b18-009027a5cd4f} - C:\Program Files (x86)\Google\Google Toolbar\GoogleToolbar_32.dll
    uRun: [msnmsgr] "C:\Program Files (x86)\Windows Live\Messenger\msnmsgr.exe" /background
    uRun: [FileHippo.com] "C:\Program Files (x86)\FileHippo.com\UpdateChecker.exe" /background
    mRun: [LManager] C:\Program Files (x86)\Launch Manager\LManager.exe
    mRun: [NortonOnlineBackupReminder] "C:\Program Files (x86)\Symantec\Norton Online Backup\Activation\NobuActivation.exe" UNATTENDED
    mRun: [AppleSyncNotifier] C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\AppleSyncNotifier.exe
    mRun: [ZoneAlarm Client] "C:\Program Files (x86)\Zone Labs\ZoneAlarm\zlclient.exe "
    mRun: [QuickTime Task] "C:\Program Files (x86)\QuickTime\QTTask.exe" -atboottime
    mRun: [iTunesHelper] "C:\Program Files (x86)\iTunes\iTunesHelper.exe "
    mRun: [SunJavaUpdateSched] "C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe "
    mRun: [Adobe ARM] "C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe "
    StartupFolder: C:\Users\walmart\AppData\Roaming\MICROS~1\Windows\STARTM~1\Programs\Startup\AVAST!~1.LNK - C:\Program Files\Alwil Software\Avast5\AvastUI.exe
    StartupFolder: C:\Users\walmart\AppData\Roaming\MICROS~1\Windows\STARTM~1\Programs\Startup\OPENOF~1.LNK - C:\Program Files (x86)\OpenOffice.org 3\program\quickstart.exe
    StartupFolder: C:\PROGRA~3\MICROS~1\Windows\STARTM~1\Programs\Startup\MCAFEE~1.LNK - C:\Program Files (x86)\McAfee Security Scan\2.1.121\SSScheduler.exe
    StartupFolder: C:\PROGRA~3\MICROS~1\Windows\STARTM~1\Programs\Startup\SECUNI~1.LNK - C:\Program Files (x86)\Secunia\PSI\psi_tray.exe
    mPolicies-system: ConsentPromptBehaviorAdmin = 5 (0x5)
    mPolicies-system: ConsentPromptBehaviorUser = 3 (0x3)
    mPolicies-system: EnableUIADesktopToggle = 0 (0x0)
    IE: E&xport to Microsoft Excel - C:\PROGRA~2\MICROS~1\Office12\EXCEL.EXE/3000
    IE: Google Sidewiki... - C:\Program Files (x86)\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_7461B1589E8B4FB7.dll/cmsidewiki.html
    IE: {0000036B-C524-4050-81A0-243669A86B9F} - {B63DBA5F-523F-4B9C-A43D-65DF1977EAD3} - C:\Program Files (x86)\Windows Live\Companion\companioncore.dll
    IE: {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - {5F7B1267-94A9-47F5-98DB-E99415F33AEC} - C:\Program Files (x86)\Windows Live\Writer\WriterBrowserExtension.dll
    IE: {2670000A-7350-4f3c-8081-5663EE0C6C49} - {48E73304-E1D6-4330-914C-F5F514E3486C} - C:\PROGRA~2\MICROS~1\Office12\ONBttnIE.dll
    IE: {92780B25-18CC-41C8-B9BE-3C9C571A8263} - {FF059E31-CC5A-4E2E-BF3B-96E929D65503} - C:\PROGRA~2\MICROS~1\Office12\REFIEBAR.DLL
    DPF: {02BCC737-B171-4746-94C9-0D8A0B2C0089} - hxxp://office.microsoft.com/sites/production/ieawsdc32.cab
    DPF: {7530BFB8-7293-4D34-9923-61A11451AFC5} - hxxp://download.eset.com/special/eos-beta/OnlineScanner.cab
    DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_26-windows-i586.cab
    DPF: {CAFEEFAC-0016-0000-0026-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_26-windows-i586.cab
    DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_26-windows-i586.cab
    DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} - hxxp://platformdl.adobe.com/NOS/getPlusPlus/1.6/gp.cab
    TCP: DhcpNameServer = 75.75.75.75 75.75.76.76
    TCP: Interfaces\{0ACAFB23-3CB5-48B5-9D25-9351FC1E144F} : DhcpNameServer = 192.168.1.1
    TCP: Interfaces\{0ACAFB23-3CB5-48B5-9D25-9351FC1E144F}\E4457425F557B46424730596549303074627D674832424D623C40563161734 : DhcpNameServer = 192.168.1.1
    TCP: Interfaces\{0ACAFB23-3CB5-48B5-9D25-9351FC1E144F}\E4457425F5C4A487679456 : DhcpNameServer = 192.168.1.1
    TCP: Interfaces\{0ACAFB23-3CB5-48B5-9D25-9351FC1E144F}\E4457425F5E43784E4A5972373242376C616E405556793948797433526576424 : DhcpNameServer = 192.168.1.1
    TCP: Interfaces\{0ACAFB23-3CB5-48B5-9D25-9351FC1E144F}\E4457425F5E49676E6C674F61326777407A685B4 : DhcpNameServer = 192.168.1.1
    TCP: Interfaces\{0ACAFB23-3CB5-48B5-9D25-9351FC1E144F}\E4457425F5F6449694752446A4539405439527951513 : DhcpNameServer = 192.168.1.1
    TCP: Interfaces\{0ACAFB23-3CB5-48B5-9D25-9351FC1E144F}\E4544574541425 : DhcpNameServer = 192.168.1.1
    TCP: Interfaces\{DD5D3D63-591C-47D3-8673-1AEDDEB14120} : DhcpNameServer = 75.75.75.75 75.75.76.76
    Handler: wlpg - {E43EF6CD-A37A-4A9B-9E6F-83F89B8E6324} - C:\Program Files (x86)\Windows Live\Photo Gallery\AlbumDownloadProtocolHandler.dll
    Handler: wot - {C2A44D6B-CB9F-4663-88A6-DF2F26E4D952} - C:\Program Files (x86)\WOT\WOT.dll
    BHO-X64: Adobe PDF Link Helper: {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
    BHO-X64: AcroIEHelperStub - No File
    BHO-X64: ZoneAlarm Toolbar: {66f2e20d-0da8-4c11-a9c8-dd8477b88acd} - C:\Program Files (x86)\ZoneAlarm\tbZone.dll
    BHO-X64: Dividend Miles Toolbar BHO: {69CD690C-70B1-4333-AD69-28FFF7118C56} - C:\Program Files (x86)\Dividend Miles Toolbar\Toolbar.dll
    BHO-X64: FCTBPos00Pos - No File
    BHO-X64: ZoneAlarm Security Engine Registrar: {8A4A36C2-0535-4D2C-BD3D-496CB7EED6E3} - C:\Program Files\CheckPoint\ZAForceField\WOW64\TrustChecker\bin\TrustCheckerIEPlugin.dll
    BHO-X64: ZoneAlarm Security Engine Registrar - No File
    BHO-X64: Windows Live ID Sign-in Helper: {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
    BHO-X64: Windows Live Messenger Companion Helper: {9FDDE16B-836F-4806-AB1F-1455CBEFF289} - C:\Program Files (x86)\Windows Live\Companion\companioncore.dll
    BHO-X64: Google Toolbar Helper: {AA58ED58-01DD-4d91-8333-CF10577473F7} - C:\Program Files (x86)\Google\Google Toolbar\GoogleToolbar_32.dll
    BHO-X64: WOT Helper: {C920E44A-7F78-4E64-BDD7-A57026E7FEB7} - C:\Program Files (x86)\WOT\WOT.dll
    BHO-X64: Java(tm) Plug-In 2 SSV Helper: {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files (x86)\Java\jre6\bin\jp2ssv.dll
    TB-X64: ZoneAlarm Security Engine: {EE2AC4E5-B0B0-4EC6-88A9-BCA1A32AB107} - C:\Program Files\CheckPoint\ZAForceField\WOW64\TrustChecker\bin\TrustCheckerIEPlugin.dll
    TB-X64: ZoneAlarm Toolbar: {66f2e20d-0da8-4c11-a9c8-dd8477b88acd} - C:\Program Files (x86)\ZoneAlarm\tbZone.dll
    TB-X64: Dividend Miles Toolbar: {3948072D-28FE-4206-9F7F-2AFF92B24679} - C:\Program Files (x86)\Dividend Miles Toolbar\Toolbar.dll
    TB-X64: WOT: {71576546-354D-41c9-AAE8-31F2EC22BF0D} - C:\Program Files (x86)\WOT\WOT.dll
    TB-X64: Google Toolbar: {2318C2B1-4965-11d4-9B18-009027A5CD4F} - C:\Program Files (x86)\Google\Google Toolbar\GoogleToolbar_32.dll
    mRun-x64: [LManager] C:\Program Files (x86)\Launch Manager\LManager.exe
    mRun-x64: [NortonOnlineBackupReminder] "C:\Program Files (x86)\Symantec\Norton Online Backup\Activation\NobuActivation.exe" UNATTENDED
    mRun-x64: [AppleSyncNotifier] C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\AppleSyncNotifier.exe
    mRun-x64: [ZoneAlarm Client] "C:\Program Files (x86)\Zone Labs\ZoneAlarm\zlclient.exe "
    mRun-x64: [QuickTime Task] "C:\Program Files (x86)\QuickTime\QTTask.exe" -atboottime
    mRun-x64: [iTunesHelper] "C:\Program Files (x86)\iTunes\iTunesHelper.exe "
    mRun-x64: [SunJavaUpdateSched] "C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe "
    mRun-x64: [Adobe ARM] "C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe "
    ================= FIREFOX ===================
    FF - ProfilePath - C:\Users\walmart\AppData\Roaming\Mozilla\Firefox\Profiles\obavtsyv.default\
    FF - prefs.js: browser.search.defaulturl - hxxp://search.conduit.com/ResultsExt.aspx?ctid=CT2611275&SearchSource=3&q={searchTerms}
    FF - prefs.js: browser.search.selectedEngine -
    FF - prefs.js: keyword.URL - chrome://browser-region/locale/region.properties
    FF - prefs.js: network.proxy.type - 0
    FF - component: C:\Program Files\CheckPoint\ZAForceField\WOW64\TrustChecker\components\TrustCheckerMozillaPlugin.dll
    FF - component: C:\Users\walmart\AppData\Roaming\Mozilla\Firefox\Profiles\obavtsyv.default\extensions\{66f2e20d-0da8-4c11-a9c8-dd8477b88acd}\components\FFExternalAlert.dll
    FF - component: C:\Users\walmart\AppData\Roaming\Mozilla\Firefox\Profiles\obavtsyv.default\extensions\{66f2e20d-0da8-4c11-a9c8-dd8477b88acd}\components\RadioWMPCore.dll
    FF - plugin: C:\Program Files (x86)\Adobe\Reader 10.0\Reader\AIR\nppdf32.dll
    FF - plugin: C:\Program Files (x86)\Google\Google Earth\plugin\npgeplugin.dll
    FF - plugin: C:\Program Files (x86)\Google\Update\1.3.21.57\npGoogleUpdate3.dll
    FF - plugin: C:\Program Files (x86)\Java\jre6\bin\new_plugin\npdeployJava1.dll
    FF - plugin: c:\Program Files (x86)\Microsoft Silverlight\4.0.60531.0\npctrlui.dll
    FF - plugin: C:\Program Files (x86)\Mozilla Firefox\plugins\npdeployJava1.dll
    FF - plugin: C:\Program Files (x86)\NOS\bin\np_gp.dll
    FF - plugin: C:\Program Files (x86)\Pando Networks\Media Booster\npPandoWebPlugin.dll
    FF - plugin: C:\Program Files (x86)\Windows Live\Photo Gallery\NPWLPG.dll
    FF - plugin: C:\Program Files\CheckPoint\ZAForceField\WOW64\TrustChecker\bin\npFFApi.dll
    FF - plugin: C:\ProgramData\NexonUS\NGM\npNxGameUS.dll
    R1 aswSnx;aswSnx;C:\Windows\system32\drivers\aswSnx.sys --> C:\Windows\system32\drivers\aswSnx.sys [?]
    R1 aswSP;aswSP;C:\Windows\system32\drivers\aswSP.sys --> C:\Windows\system32\drivers\aswSP.sys [?]
    R1 vwififlt;Virtual WiFi Filter Driver;C:\Windows\system32\DRIVERS\vwififlt.sys --> C:\Windows\system32\DRIVERS\vwififlt.sys [?]
    R2 AdobeARMservice;Adobe Acrobat Update Service;C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe [2011-6-6 64952]
    R2 aswFsBlk;aswFsBlk;C:\Windows\system32\drivers\aswFsBlk.sys --> C:\Windows\system32\drivers\aswFsBlk.sys [?]
    R2 aswMonFlt;aswMonFlt;\??\C:\Windows\system32\drivers\aswMonFlt.sys --> C:\Windows\system32\drivers\aswMonFlt.sys [?]
    R2 avast! Antivirus;avast! Antivirus;C:\Program Files\Alwil Software\Avast5\AvastSvc.exe [2011-9-7 44768]
    R2 ePowerSvc;Acer ePower Service;C:\Program Files\eMachines\eMachines Power Management\ePowerSvc.exe [2009-11-5 844320]
    R2 Greg_Service;GRegService;C:\Program Files (x86)\eMachines\Registration\GregHSRW.exe [2009-8-28 1150496]
    R2 ISWKL;ZoneAlarm Toolbar ISWKL;C:\Program Files\CheckPoint\ZAForceField\ISWKL.sys [2009-10-14 33008]
    R2 IswSvc;ZoneAlarm Toolbar IswSvc;C:\Program Files\CheckPoint\ZAForceField\ISWSVC.exe [2009-10-14 823272]
    R2 NTISchedulerSvc;NTI Backup Now 5 Scheduler Service;C:\Program Files (x86)\NewTech Infosystems\NTI Backup Now 5\SchedulerSvc.exe [2009-6-17 144640]
    R2 Secunia PSI Agent;Secunia PSI Agent;C:\Program Files (x86)\Secunia\PSI\psia.exe [2011-4-19 993848]
    R2 Secunia Update Agent;Secunia Update Agent;C:\Program Files (x86)\Secunia\PSI\sua.exe [2011-4-19 399416]
    R2 Updater Service;Updater Service;C:\Program Files\eMachines\eMachines Updater\UpdaterService.exe [2009-11-5 240160]
    R3 L1C;NDIS Miniport Driver for Atheros AR8131/AR8132 PCI-E Ethernet Controller (NDIS 6.20);C:\Windows\system32\DRIVERS\L1C62x64.sys --> C:\Windows\system32\DRIVERS\L1C62x64.sys [?]
    R3 PSI;PSI;C:\Windows\system32\DRIVERS\psi_mf.sys --> C:\Windows\system32\DRIVERS\psi_mf.sys [?]
    R3 SaiH5F0D;SaiH5F0D;C:\Windows\system32\DRIVERS\SaiH5F0D.sys --> C:\Windows\system32\DRIVERS\SaiH5F0D.sys [?]
    R3 SaiU5F0D;SaiU5F0D;C:\Windows\system32\DRIVERS\SaiU5F0D.sys --> C:\Windows\system32\DRIVERS\SaiU5F0D.sys [?]
    S2 clr_optimization_v4.0.30319_32;Microsoft .NET Framework NGEN v4.0.30319_X86;C:\Windows\Microsoft.NET\Framework\v4.0.30319\mscorsvw.exe [2010-3-18 130384]
    S2 clr_optimization_v4.0.30319_64;Microsoft .NET Framework NGEN v4.0.30319_X64;C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscorsvw.exe [2010-3-18 138576]
    S2 gupdate;Google Update Service (gupdate);C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [2010-3-13 135664]
    S3 fssfltr;fssfltr;C:\Windows\system32\DRIVERS\fssfltr.sys --> C:\Windows\system32\DRIVERS\fssfltr.sys [?]
    S3 fsssvc;Windows Live Family Safety Service;C:\Program Files (x86)\Windows Live\Family Safety\fsssvc.exe [2011-5-13 1492840]
    S3 gupdatem;Google Update Service (gupdatem);C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [2010-3-13 135664]
    S3 McComponentHostService;McAfee Security Scan Component Host Service;C:\Program Files (x86)\McAfee Security Scan\2.1.121\McCHSvc.exe [2010-9-3 227232]
    S3 nosGetPlusHelper;getPlus(R) Helper 3004;C:\Windows\System32\svchost.exe -k nosGetPlusHelper [2009-7-13 20992]
    S3 NTIBackupSvc;NTI Backup Now 5 Backup Service;C:\Program Files (x86)\NewTech Infosystems\NTI Backup Now 5\BackupSvc.exe [2009-6-17 50432]
    S3 RSUSBSTOR;RtsUStor.Sys Realtek USB Card Reader;C:\Windows\System32\drivers\RtsUStor.sys [2009-11-5 225280]
    S3 TsUsbFlt;TsUsbFlt;C:\Windows\system32\drivers\tsusbflt.sys --> C:\Windows\system32\drivers\tsusbflt.sys [?]
    S3 WatAdminSvc;Windows Activation Technologies Service;C:\Windows\system32\Wat\WatAdminSvc.exe --> C:\Windows\system32\Wat\WatAdminSvc.exe [?]
    S3 WN111v2;NETGEAR WN111v2 USB2.0 Wireless Card Service;C:\Windows\system32\DRIVERS\WN111v2x.sys --> C:\Windows\system32\DRIVERS\WN111v2x.sys [?]
    S4 wlcrasvc;Windows Live Mesh remote connections service;C:\Program Files\Windows Live\Mesh\wlcrasvc.exe [2010-9-22 57184]
    2011-10-26 20:40:40 69000 ----a-w- C:\ProgramData\Microsoft\Windows Defender\Definition Updates\{A08FB619-D4D1-41B2-BD8F-1FE76DB923C9}\offreg.dll
    2011-10-26 19:10:57 -------- d-----w- C:\Users\walmart\AppData\Local\{6A644991-5B37-4E7D-A4EE-FE89F85B2764}
    2011-10-26 19:10:36 -------- d-----w- C:\Users\walmart\AppData\Local\{9242ED3B-E601-4CBF-9EBD-EE7163144579}
    2011-10-25 15:54:02 8570192 ----a-w- C:\ProgramData\Microsoft\Windows Defender\Definition Updates\{A08FB619-D4D1-41B2-BD8F-1FE76DB923C9}\mpengine.dll
    2011-10-19 21:20:11 -------- d-----w- C:\Users\walmart\AppData\Local\{6CBB83BD-EF16-45AE-BFDD-955B2458D5BE}
    2011-10-19 21:19:56 -------- d-----w- C:\Users\walmart\AppData\Local\{A7F6B245-93D9-4F05-BD2F-C8366083F0A1}
    2011-10-13 14:51:27 -------- d-----w- C:\Users\walmart\AppData\Local\{9AA81FD0-F250-49C3-93F5-BBA118858D23}
    2011-10-13 01:27:20 3138048 ----a-w- C:\Windows\System32\win32k.sys
    2011-10-13 01:24:18 75776 ----a-w- C:\Windows\SysWow64\psisrndr.ax
    2011-10-13 01:24:18 613888 ----a-w- C:\Windows\System32\psisdecd.dll
    2011-10-13 01:24:17 465408 ----a-w- C:\Windows\SysWow64\psisdecd.dll
    2011-10-13 01:24:16 108032 ----a-w- C:\Windows\System32\psisrndr.ax
    2011-10-13 01:23:33 331776 ----a-w- C:\Windows\System32\oleacc.dll
    2011-10-13 01:23:32 233472 ----a-w- C:\Windows\SysWow64\oleacc.dll
    2011-10-13 01:23:31 571904 ----a-w- C:\Windows\SysWow64\oleaut32.dll
    2011-10-13 01:23:30 861696 ----a-w- C:\Windows\System32\oleaut32.dll
    2011-10-11 18:03:42 -------- d-----w- C:\Users\walmart\AppData\Local\{4141F796-A18F-4397-82E5-EADEDAFB43CA}
    2011-10-11 18:03:28 -------- d-----w- C:\Users\walmart\AppData\Local\{EDFEDC4D-AFCF-4B38-9FB3-3E9DA2306688}
    2011-10-06 15:58:26 -------- d-----w- C:\Users\walmart\AppData\Local\{018EA0C3-C20B-4F85-853C-6AEB75F18F0D}
    2011-10-06 15:58:09 -------- d-----w- C:\Users\walmart\AppData\Local\{D2444C4B-2015-4CC6-8A4C-15D8D86FEAD5}
    2011-10-01 19:09:57 -------- d-----w- C:\Users\walmart\AppData\Local\{4B920E80-D140-47C0-B327-30051B2FFDEA}
    2011-10-01 19:09:18 -------- d-----w- C:\Users\walmart\AppData\Local\{DFB829AF-A773-43C6-8F49-03EB08E6AE23}
    2011-10-01 17:39:37 -------- d-----w- C:\Users\walmart\AppData\Local\{C964C2C1-55E5-4D66-BEDE-7178A29BCFFF}
    2011-10-01 17:39:19 -------- d-----w- C:\Users\walmart\AppData\Local\{6A974712-3BAC-4C9A-A34C-5FAF11B0F0D8}
    2011-09-06 20:45:29 41184 ----a-w- C:\Windows\avastSS.scr
    2011-09-06 20:38:18 601944 ----a-w- C:\Windows\System32\drivers\aswSnx.sys
    2011-09-06 20:36:30 65368 ----a-w- C:\Windows\System32\drivers\aswMonFlt.sys
    2011-09-01 05:24:07 2309120 ----a-w- C:\Windows\System32\jscript9.dll
    2011-09-01 05:17:57 1389056 ----a-w- C:\Windows\System32\wininet.dll
    2011-09-01 05:12:04 2382848 ----a-w- C:\Windows\System32\mshtml.tlb
    2011-09-01 02:35:59 1798144 ----a-w- C:\Windows\SysWow64\jscript9.dll
    2011-09-01 02:28:15 1126912 ----a-w- C:\Windows\SysWow64\wininet.dll
    2011-09-01 02:22:54 2382848 ----a-w- C:\Windows\SysWow64\mshtml.tlb
    2011-08-10 19:42:28 404640 ----a-w- C:\Windows\SysWow64\FlashPlayerCPLApp.cpl
    ============= FINISH: 17:40:18.91 ===============
  5. 2011/10/26
    Forsaken Knight
    UNLESS SPECIFICALLY INSTRUCTED, DO NOT POST THIS LOG.
    IF REQUESTED, ZIP IT UP & ATTACH IT
    Boot Device: \Device\HarddiskVolume2
    Install Date: 3/1/2010 6:28:55 AM
    System Uptime: 10/26/2011 4:37:02 PM (1 hours ago)
    Motherboard: eMachines | | eMachines E725
    Processor: Pentium(R) Dual-Core CPU T4400 @ 2.20GHz | uPGA-478 | 1584/200mhz
    ==== Disk Partitions =========================
    C: is FIXED (NTFS) - 221 GiB total, 147.211 GiB free.
    D: is CDROM ()
    ==== Disabled Device Manager Items =============
    Class GUID: {4d36e972-e325-11ce-bfc1-08002be10318}
    Description: Microsoft Teredo Tunneling Adapter
    Device ID: ROOT\*TEREDO\0000
    Manufacturer: Microsoft
    Name: Teredo Tunneling Pseudo-Interface
    PNP Device ID: ROOT\*TEREDO\0000
    Service: tunnel
    ==== System Restore Points ===================
    RP314: 10/2/2011 7:00:16 PM - Windows Backup
    RP315: 10/4/2011 9:08:41 AM - Windows Update
    RP316: 10/7/2011 11:33:08 AM - Windows Update
    RP317: 10/9/2011 8:31:34 PM - Windows Backup
    RP318: 10/11/2011 12:04:35 PM - Windows Update
    RP319: 10/13/2011 10:14:47 AM - Windows Update
    RP320: 10/16/2011 7:00:22 PM - Windows Backup
    RP321: 10/18/2011 10:40:51 AM - Windows Update
    RP322: 10/21/2011 11:54:25 AM - Windows Update
    RP323: 10/23/2011 7:22:00 PM - Windows Backup
    RP324: 10/25/2011 11:53:15 AM - Windows Update
    RP325: 10/26/2011 10:43:24 AM - Windows Update
    ==== Installed Programs ======================
    Update for Microsoft Office 2007 (KB2508958)
    2007 Microsoft Office Suite Service Pack 2 (SP2)
    Acrobat.com
    Adobe Acrobat 4.0
    Adobe AIR
    Adobe Download Manager
    Adobe Flash Player 10 ActiveX
    Adobe Reader X (10.1.1)
    Age Of Wonders
    AirRivals_EN 1.0.0.39
    Apple Application Support
    Apple Software Update
    Atheros Communications Inc.(R) AR81Family Gigabit/Fast Ethernet Driver
    avast! Free Antivirus
    Compatibility Pack for the 2007 Office system
    D3DX10
    DFOLauncher
    eBay Worldwide
    eMachines Games
    eMachines Recovery Management
    eMachines Registration
    eMachines ScreenSaver
    eMachines Updater
    ESET Online Scanner v3
    FileHippo.com Update Checker
    Google Chrome
    Google Earth
    Google Toolbar for Internet Explorer
    Google Update Helper
    Identity Card
    Java Auto Updater
    Java(TM) 6 Update 26
    JetFighter IV
    Junk Mail filter update
    Launch Manager
    McAfee Security Scan Plus
    Mesh Runtime
    Messenger Companion
    Microsoft Office Access MUI (English) 2007
    Microsoft Office Access Setup Metadata MUI (English) 2007
    Microsoft Office Excel MUI (English) 2007
    Microsoft Office File Validation Add-In
    Microsoft Office Home and Student 2007
    Microsoft Office InfoPath MUI (English) 2007
    Microsoft Office OneNote MUI (English) 2007
    Microsoft Office Outlook Connector
    Microsoft Office Outlook MUI (English) 2007
    Microsoft Office PowerPoint MUI (English) 2007
    Microsoft Office PowerPoint Viewer 2007 (English)
    Microsoft Office Professional Plus 2007
    Microsoft Office Proof (English) 2007
    Microsoft Office Proof (French) 2007
    Microsoft Office Proof (Spanish) 2007
    Microsoft Office Proofing (English) 2007
    Microsoft Office Publisher MUI (English) 2007
    Microsoft Office Shared MUI (English) 2007
    Microsoft Office Shared Setup Metadata MUI (English) 2007
    Microsoft Office Suite Activation Assistant
    Microsoft Office Word MUI (English) 2007
    Microsoft SQL Server 2005 Compact Edition [ENU]
    Microsoft Visual C++ 2005 ATL Update kb973923 - x86 8.0.50727.4053
    Microsoft Visual C++ 2005 Redistributable
    Microsoft Visual C++ 2008 Redistributable - KB2467174 - x86 9.0.30729.5570
    Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148
    Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.6161
    Microsoft Works
    Mozilla Firefox 4.0.1 (x86 en-US)
    MSVCRT
    MSVCRT_amd64
    MyScribe
    Nexon Game Manager
    NTI Backup Now 5
    NTI Backup Now Standard
    NTI Media Maker 8
    OpenOffice.org 3.2
    Pando Media Booster
    QuickTime
    Realtek High Definition Audio Driver
    Realtek USB 2.0 Card Reader
    Safari
    Secunia PSI (2.0.0.3003)
    Security Update for 2007 Microsoft Office System (KB2288621)
    Security Update for 2007 Microsoft Office System (KB2288931)
    Security Update for 2007 Microsoft Office System (KB2345043)
    Security Update for 2007 Microsoft Office System (KB2553074)
    Security Update for 2007 Microsoft Office System (KB2553089)
    Security Update for 2007 Microsoft Office System (KB2553090)
    Security Update for 2007 Microsoft Office System (KB2584063)
    Security Update for 2007 Microsoft Office System (KB969559)
    Security Update for 2007 Microsoft Office System (KB976321)
    Security Update for Microsoft .NET Framework 4 Client Profile (KB2160841)
    Security Update for Microsoft .NET Framework 4 Client Profile (KB2446708)
    Security Update for Microsoft .NET Framework 4 Client Profile (KB2478663)
    Security Update for Microsoft .NET Framework 4 Client Profile (KB2518870)
    Security Update for Microsoft .NET Framework 4 Client Profile (KB2539636)
    Security Update for Microsoft .NET Framework 4 Client Profile (KB2572078)
    Security Update for Microsoft Office Access 2007 (KB979440)
    Security Update for Microsoft Office Excel 2007 (KB2553073)
    Security Update for Microsoft Office InfoPath 2007 (KB2510061)
    Security Update for Microsoft Office InfoPath 2007 (KB979441)
    Security Update for Microsoft Office PowerPoint 2007 (KB2535818)
    Security Update for Microsoft Office PowerPoint Viewer 2007 (KB2464623)
    Security Update for Microsoft Office Publisher 2007 (KB2284697)
    Security Update for Microsoft Office system 2007 (972581)
    Security Update for Microsoft Office system 2007 (KB974234)
    Security Update for Microsoft Office Visio Viewer 2007 (KB973709)
    Security Update for Microsoft Office Word 2007 (KB2344993)
    Update for 2007 Microsoft Office System (KB2284654)
    Update for 2007 Microsoft Office System (KB967642)
    Update for Microsoft .NET Framework 4 Client Profile (KB2468871)
    Update for Microsoft .NET Framework 4 Client Profile (KB2533523)
    Update for Microsoft Office 2007 Help for Common Features (KB963673)
    Update for Microsoft Office 2007 System (KB2539530)
    Update for Microsoft Office Access 2007 Help (KB963663)
    Update for Microsoft Office Excel 2007 Help (KB963678)
    Update for Microsoft Office Infopath 2007 Help (KB963662)
    Update for Microsoft Office OneNote 2007 (KB980729)
    Update for Microsoft Office OneNote 2007 Help (KB963670)
    Update for Microsoft Office Outlook 2007 (KB2583910)
    Update for Microsoft Office Outlook 2007 Help (KB963677)
    Update for Microsoft Office Powerpoint 2007 Help (KB963669)
    Update for Microsoft Office Publisher 2007 Help (KB963667)
    Update for Microsoft Office Script Editor Help (KB963671)
    Update for Microsoft Office Word 2007 Help (KB963665)
    Update for Outlook 2007 Junk Email Filter (KB2596560)
    Welcome Center
    Windows Live Communications Platform
    Windows Live Essentials
    Windows Live Installer
    Windows Live Mail
    Windows Live Mesh
    Windows Live Mesh ActiveX Control for Remote Connections
    Windows Live Messenger Companion Core
    Windows Live Movie Maker
    Windows Live Photo Common
    Windows Live Photo Gallery
    Windows Live PIMT Platform
    Windows Live SOXE
    Windows Live SOXE Definitions
    Windows Live Sync
    Windows Live UX Platform
    Windows Live UX Platform Language Pack
    Windows Live Writer
    Windows Live Writer Resources
    WOT for Internet Explorer
    ZoneAlarm
    ==== Event Viewer Messages From Past Week ========
    10/25/2011 8:21:56 PM, Error: Service Control Manager [7011] - A timeout (30000 milliseconds) was reached while waiting for a transaction response from the lmhosts service.
    10/25/2011 11:41:45 AM, Error: Service Control Manager [7011] - A timeout (30000 milliseconds) was reached while waiting for a transaction response from the NlaSvc service.
    10/23/2011 11:14:41 AM, Error: Service Control Manager [7011] - A timeout (30000 milliseconds) was reached while waiting for a transaction response from the Netman service.
    10/21/2011 11:41:24 AM, Error: Service Control Manager [7011] - A timeout (30000 milliseconds) was reached while waiting for a transaction response from the WinDefend service.
    10/19/2011 6:32:37 PM, Error: Service Control Manager [7022] - The Windows Update service hung on starting.
    ==== End Of File ===========================
  6. 2011/10/26
    Forsaken Knight
    Ok, I guess thats it for now. I'll check back later on to see if I get a reply within this thread.
  7. 2011/10/26
    Please, observe following rules:
    • Read all of my instructions very carefully. Your mistakes during cleaning process may have very serious consequences, like unbootable computer.
    • If you're stuck, or you're not sure about certain step, always ask before doing anything else.
    • Please refrain from running tools or applying updates other than those I suggest.
    • Never run more than one scan at a time.
    • Keep updating me regarding your computer behavior, good, or bad.
    • The cleaning process, once started, has to be completed. Even if your computer appears to act better, it may still be infected. Once the computer is totally clean, I'll certainly let you know.
    • If you leave the topic without explanation in the middle of a cleaning process, you may not be eligible to receive any more help in malware removal forum.
    • I close my topics if you have not replied in 5 days. If you need more time, simply let me know. If I closed your topic and you need it to be reopened, simply PM me.
    1. Uninstall Malwarebytes' Anti-Malware using Add/Remove programs in the control panel.
    2. Restart your computer (very important).
    3. Download and run this utility.
    4. It will ask to restart your computer (please allow it to).
    5. After the computer restarts, install the latest version from here.
    Let me know if it worked.
    Download Bootkit Remover to your Desktop.
    • Unzip downloaded file to your Desktop.
    • Double-click on remover.exe to run the program (Vista/7 users,right click on remover.exe and click Run As Administrator).
    • It will show a Black screen with some data on it.
    • Right click on the screen and click Select All.
    • Press CTRL+C
    • Open a Notepad and press CTRL+V
    • Post the output back here.
  8. 2011/10/27
    Forsaken Knight
    Forsaken Knight
    Bootkit Remover
    (c) 2009 Esage Lab
    www.esagelab.com
    Program version: 1.2.0.1
    OS Version: Microsoft Windows 7 Home Premium Edition Service Pack 1 (build 7601)
    , 64-bit
    System volume is \\.\C:
    \\.\C: -> \\.\PhysicalDrive0 at offset 0x00000003`069e5800
    Boot sector MD5 is: bb4f1627d8b9beda49ac0d010229f3ff
    Size Device Name MBR Status
    232 GB \\.\PhysicalDrive0 OK (DOS/Win32 Boot code found)
    Done;
    Press any key to quit...
  10. 2011/10/27
    So far I don't see much....
    [color= "Blue"]**Note: In the event you already have Combofix, this is a new version that I need you to download. It is important that it is saved directly to your desktop**[/color]
    2. Close any open browsers.
      • Click on [color= "Red"]this link[/color] to see a list of programs that should be disabled. The list is not all inclusive. If yours is not listed and you don't know how to disable it, please ask.
      NOTE1. If Combofix asks you to install Recovery Console, please allow it.
      • Close any open browsers.
      • [color= "Red"]WARNING:[/color] Combofix will disconnect your machine from the Internet as soon as it starts
    6. Please post the "C:\ComboFix.txt"
    **Note 1: Do not mouseclick combofix's window while it's running. That may cause it to stall
    **Note 2 for AVG users: ComboFix will not run until AVG is uninstalled as a protective measure against the anti-virus. This is because AVG "falsely" detects ComboFix (or its embedded files) as a threat and may remove them resulting in the tool not working correctly which in turn can cause "unpredictable results ". Since AVG cannot be effectively disabled before running ComboFix, the author recommends you to uninstall AVG first.
    Use AppRemover to uninstall it: http://www.appremover.com/
    We can reinstall it when we're done with CF.
    **Note 3: If you receive an error "Illegal operation attempted on a registery key that has been marked for deletion ", restart computer to fix the issue.
    NOTE.
    If, for some reason, Combofix refuses to run, try one of the following:
    1. Run Combofix from Safe Mode (How to...)
    2. Delete Combofix file, download fresh one, but rename combofix.exe to yourname.exe BEFORE saving it to your desktop.
    Do NOT run it yet.
    Please download and run the below tool named Rkill (courtesy of BleepingComputer.com) which may help allow other programs to run.
    There are 4 different versions. If one of them won't run then download and try to run the other one.
    Vista and Win7 users need to right click Rkill and choose Run as Administrator
    You only need to get one of these to run, not all of them. You may get warnings from your antivirus about this tool, ignore them or shutdown your antivirus.
    Rkill.com
    Rkill.scr
    Rkill.exe
    • Double-click on the Rkill desktop icon to run the tool.
    • If using Vista or Windows 7 right-click on it and choose Run As Administrator.
    • A black DOS box will briefly flash and then disappear. This is normal and indicates the tool ran successfully.
    • If not, delete the file, then download and use the one provided in Link 2.
    • If it does not work, repeat the process and attempt to use one of the remaining links until the tool runs.
    • Do not reboot until instructed.
    • If the tool does not run from any of the links provided, please let me know.
    Once you've gotten one of them to run, immediately run your_name.exe by double clicking on it.
    If normal mode still doesn't work, run BOTH tools from safe mode.
    In case #2, please post BOTH logs, rKill and Combofix.
  11. 2011/10/31
    Forsaken Knight
    http://imageshack.us/photo/my-images/408/errorwhentryingtodownlo.png/
    http://imageshack.us/photo/my-images/810/thingwhenrunningcombofi.png/
    Tried to download combofix, had an error when trying to run it. I think there is something that is preventing me from downloading and installing new programs. I would like to know what that is, and remove that prevention.
    Anyways, I then did a search from the start menu for combofix. This is why I don't like to delete programs that are meant to help fix my system. I never know if I can get them again. I had combofix still on my pc, so I ran it. It kept stalling in normal window mode after reaching stage 50. I then shut down my pc after closing the combofix window, and tried running rkill before running combofix. I did this via the link provided in this recent post of yours broni, and it worked. I think as long as I just run the program, instead of save as, then the program will not have a problem, like when I noticed this issue when trying to uninstall and reinstall malwarebytes. Anyways, after rkill, combofix ran ok, up until the stage 50 was completed, and still wouldn't do anything for twenty minutes after reaching that point. So, like before, I closed combofix, and then restarted up and went into safe mode (no network). I just ran alone combofix, and it ran fine, though, after reaching stage 50, I noticed when I got back to check on my pc (took out the garbage), that my system was in normal mode now. Took a bit after that, to open up the log file, about twelve minutes, and then I was able to save the file. Though, for some odd reason, I couldn't open up a IE or any other program, so I just restarted my pc. Here is the combofix log report.
  12. 2011/10/31
    Forsaken Knight
    This log file is located at C:\rkill.log.
    Please post this only if requested to by the person helping you.
    Otherwise you can close this log when you wish.
    Rkill was run on 10/31/2011 at 17:42:19.
    Operating System: Windows 7 Home Premium
    Processes terminated by Rkill or while it was running:
    C:\Program Files\Alwil Software\Avast5\defs\11103100\Sf.bin
    Rkill completed on 10/31/2011 at 17:43:07.
  13. 2011/10/31
    Forsaken Knight
    ComboFix 11-10-30.04 - walmart 10/31/2011 18:02:10.4.2 - x64 MINIMAL
    Microsoft Windows 7 Home Premium 6.1.7601.1.1252.1.1033.18.3002.1903 [GMT -4:00]
    Running from: c:\users\walmart\Desktop\removalable disk e items transfered on thur fed 17 2011\Exe files downloaded onto flash drive from windows bbs web site\ComboFix.exe
    AV: avast! Antivirus *Disabled/Updated* {2B2D1395-420B-D5C9-657E-930FE358FC3C}
    SP: avast! Antivirus *Disabled/Updated* {904CF271-6431-DA47-5FCE-A87D98DFB681}
    * Created a new restore point
    ((((((((((((((((((((((((( Files Created from 2011-09-28 to 2011-10-31 )))))))))))))))))))))))))))))))
    2011-10-31 22:08 . 2011-10-31 22:08 -------- d-----w- c:\users\Public\AppData\Local\temp
    2011-10-31 22:08 . 2011-10-31 22:08 -------- d-----w- c:\users\Default\AppData\Local\temp
    2011-10-31 22:08 . 2011-10-31 22:08 -------- d-----w- c:\users\AppData\AppData\Local\temp
    2011-10-28 14:13 . 2011-10-07 04:16 8570192 ----a-w- c:\programdata\Microsoft\Windows Defender\Definition Updates\{17D8894B-88C9-40DD-8D76-B70719F4DE46}\mpengine.dll
    2011-10-28 02:16 . 2011-10-28 02:16 -------- d-----w- c:\users\walmart\AppData\Roaming\Malwarebytes
    2011-10-28 02:15 . 2011-10-28 02:15 -------- d-----w- c:\programdata\Malwarebytes
    2011-10-28 02:15 . 2011-10-28 02:16 -------- d-----w- c:\program files (x86)\Malwarebytes' Anti-Malware
    2011-10-28 02:15 . 2011-08-31 21:00 25416 ----a-w- c:\windows\system32\drivers\mbam.sys
    2011-10-19 19:38 . 2011-10-19 19:38 -------- d-----w- c:\program files (x86)\Apple Software Update
    2011-10-13 01:27 . 2011-09-06 03:03 3138048 ----a-w- c:\windows\system32\win32k.sys
    2011-10-13 01:24 . 2011-08-17 05:26 613888 ----a-w- c:\windows\system32\psisdecd.dll
    2011-10-13 01:24 . 2011-08-17 04:19 75776 ----a-w- c:\windows\SysWow64\psisrndr.ax
    2011-10-13 01:24 . 2011-08-17 04:24 465408 ----a-w- c:\windows\SysWow64\psisdecd.dll
    2011-10-13 01:24 . 2011-08-17 05:25 108032 ----a-w- c:\windows\system32\psisrndr.ax
    2011-10-13 01:23 . 2011-08-27 05:37 331776 ----a-w- c:\windows\system32\oleacc.dll
    2011-10-13 01:23 . 2011-08-27 04:26 233472 ----a-w- c:\windows\SysWow64\oleacc.dll
    2011-10-13 01:23 . 2011-08-27 04:26 571904 ----a-w- c:\windows\SysWow64\oleaut32.dll
    2011-10-13 01:23 . 2011-08-27 05:37 861696 ----a-w- c:\windows\system32\oleaut32.dll
    2011-10-31 22:13 . 2011-10-31 22:13 69000 ----a-w- c:\programdata\Microsoft\Windows Defender\Definition Updates\{17D8894B-88C9-40DD-8D76-B70719F4DE46}\offreg.dll
    2011-09-06 20:45 . 2011-01-09 22:27 41184 ----a-w- c:\windows\avastSS.scr
    2011-09-06 20:45 . 2010-05-03 04:02 199304 ----a-w- c:\windows\SysWow64\aswBoot.exe
    2011-09-06 20:45 . 2011-02-05 20:05 254400 ----a-w- c:\windows\system32\aswBoot.exe
    2011-09-06 20:38 . 2011-04-18 20:34 601944 ----a-w- c:\windows\system32\drivers\aswSnx.sys
    2011-09-06 20:38 . 2010-05-03 04:02 301912 ----a-w- c:\windows\system32\drivers\aswSP.sys
    2011-09-06 20:36 . 2010-05-03 04:02 58200 ----a-w- c:\windows\system32\drivers\aswTdi.sys
    2011-09-06 20:36 . 2010-05-03 04:02 42328 ----a-w- c:\windows\system32\drivers\aswRdr.sys
    2011-09-06 20:36 . 2010-05-03 04:02 65368 ----a-w- c:\windows\system32\drivers\aswMonFlt.sys
    2011-09-06 20:36 . 2010-05-03 04:02 24408 ----a-w- c:\windows\system32\drivers\aswFsBlk.sys
    2011-08-12 15:33 . 2011-08-12 15:33 18328 ----a-w- c:\programdata\Microsoft\IdentityCRL\production\ppcrlconfig600.dll
    2011-08-10 19:42 . 2011-08-10 19:42 404640 ----a-w- c:\windows\SysWow64\FlashPlayerCPLApp.cpl
    [HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\URLSearchHooks]
    "{66f2e20d-0da8-4c11-a9c8-dd8477b88acd} "= "c:\program files (x86)\ZoneAlarm\tbZone.dll" [2010-05-09 2517088]
    "{868978c8-95f3-4020-a5cd-5a16d60e36ca} "= "c:\program files (x86)\Dividend Miles Toolbar\Helper.dll" [2011-06-09 357376]
    [HKEY_CLASSES_ROOT\clsid\{66f2e20d-0da8-4c11-a9c8-dd8477b88acd}]
    [HKEY_CLASSES_ROOT\clsid\{868978c8-95f3-4020-a5cd-5a16d60e36ca}]
    [HKEY_CLASSES_ROOT\FreeCauseURLSearchHook.FCToolbarURLSearchHook.1]
    [HKEY_CLASSES_ROOT\TypeLib\{18AB4FA0-5522-4114-9654-5CCE2F9D172E}]
    [HKEY_CLASSES_ROOT\FreeCauseURLSearchHook.FCToolbarURLSearchHook]
    [HKEY_LOCAL_MACHINE\Wow6432Node\~\Browser Helper Objects\{66f2e20d-0da8-4c11-a9c8-dd8477b88acd}]
    2010-05-09 15:50 2517088 ----a-w- c:\program files (x86)\ZoneAlarm\tbZone.dll
    [HKEY_LOCAL_MACHINE\Wow6432Node\~\Browser Helper Objects\{69CD690C-70B1-4333-AD69-28FFF7118C56}]
    2011-06-09 01:27 1544192 ----a-w- c:\program files (x86)\Dividend Miles Toolbar\Toolbar.dll
    [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Toolbar]
    "{3948072D-28FE-4206-9F7F-2AFF92B24679} "= "c:\program files (x86)\Dividend Miles Toolbar\Toolbar.dll" [2011-06-09 1544192]
    [HKEY_CLASSES_ROOT\clsid\{3948072d-28fe-4206-9f7f-2aff92b24679}]
    [HKEY_CLASSES_ROOT\FCTB000063323.IEToolbar.1]
    [HKEY_CLASSES_ROOT\TypeLib\{8406FB26-8A92-4574-8C97-410FCDAD7F00}]
    [HKEY_CLASSES_ROOT\FCTB000063323.IEToolbar]
    "msnmsgr "= "c:\program files (x86)\Windows Live\Messenger\msnmsgr.exe" [2011-05-13 4283256]
    "FileHippo.com "= "c:\program files (x86)\FileHippo.com\UpdateChecker.exe" [2010-08-09 248832]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Run]
    "LManager "= "c:\program files (x86)\Launch Manager\LManager.exe" [2009-08-18 1157128]
    "NortonOnlineBackupReminder "= "c:\program files (x86)\Symantec\Norton Online Backup\Activation\NobuActivation.exe" [2009-07-25 588648]
    "AppleSyncNotifier "= "c:\program files (x86)\Common Files\Apple\Mobile Device Support\AppleSyncNotifier.exe" [2010-04-13 47392]
    "ZoneAlarm Client "= "c:\program files (x86)\Zone Labs\ZoneAlarm\zlclient.exe" [2010-06-23 1043968]
    "QuickTime Task "= "c:\program files (x86)\QuickTime\QTTask.exe" [2010-11-29 421888]
    "iTunesHelper "= "c:\program files (x86)\iTunes\iTunesHelper.exe" [2011-04-14 421160]
    "SunJavaUpdateSched "= "c:\program files (x86)\Common Files\Java\Java Update\jusched.exe" [2011-04-08 254696]
    "Adobe ARM "= "c:\program files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe" [2011-06-06 937920]
    c:\users\walmart\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\
    avast! Free Antivirus.lnk - c:\program files\Alwil Software\Avast5\AvastUI.exe [2011-9-7 3722416]
    OpenOffice.org 3.2.lnk - c:\program files (x86)\OpenOffice.org 3\program\quickstart.exe [2009-12-15 384000]
    c:\programdata\Microsoft\Windows\Start Menu\Programs\Startup\
    McAfee Security Scan Plus.lnk - c:\program files (x86)\McAfee Security Scan\2.1.121\SSScheduler.exe [2010-9-3 255536]
    Secunia PSI Tray.lnk - c:\program files (x86)\Secunia\PSI\psi_tray.exe [2011-4-19 291896]
    [HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\policies\system]
    "ConsentPromptBehaviorAdmin "= 5 (0x5)
    "ConsentPromptBehaviorUser "= 3 (0x3)
    "EnableUIADesktopToggle "= 0 (0x0)
    [HKEY_LOCAL_MACHINE\software\wow6432node\microsoft\windows nt\currentversion\drivers32]
    "aux "=wdmaud.drv
    [HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa]
    Security Packages REG_MULTI_SZ kerberos msv1_0 schannel wdigest tspkg pku2u livessp
    R2 clr_optimization_v4.0.30319_32;Microsoft .NET Framework NGEN v4.0.30319_X86;c:\windows\Microsoft.NET\Framework\v4.0.30319\mscorsvw.exe [2010-03-18 130384]
    R2 clr_optimization_v4.0.30319_64;Microsoft .NET Framework NGEN v4.0.30319_X64;c:\windows\Microsoft.NET\Framework64\v4.0.30319\mscorsvw.exe [2010-03-18 138576]
    R2 gupdate;Google Update Service (gupdate);c:\program files (x86)\Google\Update\GoogleUpdate.exe [2010-03-13 135664]
    R3 EagleX64;EagleX64;c:\windows\system32\drivers\EagleX64.sys [x]
    R3 gupdatem;Google Update Service (gupdatem);c:\program files (x86)\Google\Update\GoogleUpdate.exe [2010-03-13 135664]
    R3 McComponentHostService;McAfee Security Scan Component Host Service;c:\program files (x86)\McAfee Security Scan\2.1.121\McCHSvc.exe [2010-09-03 227232]
    R3 nosGetPlusHelper;getPlus(R) Helper 3004;c:\windows\System32\svchost.exe [2009-07-14 27136]
    R3 NTIBackupSvc;NTI Backup Now 5 Backup Service;c:\program files (x86)\NewTech Infosystems\NTI Backup Now 5\BackupSvc.exe [2009-06-18 50432]
    R3 RSUSBSTOR;RtsUStor.Sys Realtek USB Card Reader;c:\windows\System32\Drivers\RtsUStor.sys [2009-09-02 225280]
    R3 TsUsbFlt;TsUsbFlt;c:\windows\system32\drivers\tsusbflt.sys [x]
    R3 WatAdminSvc;Windows Activation Technologies Service;c:\windows\system32\Wat\WatAdminSvc.exe [x]
    R3 WN111v2;NETGEAR WN111v2 USB2.0 Wireless Card Service;c:\windows\system32\DRIVERS\WN111v2x.sys [x]
    R4 wlcrasvc;Windows Live Mesh remote connections service;c:\program files\Windows Live\Mesh\wlcrasvc.exe [2010-09-22 57184]
    S1 aswSnx;aswSnx; [x]
    S1 aswSP;aswSP; [x]
    S1 vwififlt;Virtual WiFi Filter Driver;c:\windows\system32\DRIVERS\vwififlt.sys [x]
    S2 AdobeARMservice;Adobe Acrobat Update Service;c:\program files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe [2011-06-06 64952]
    S2 aswFsBlk;aswFsBlk; [x]
    S2 aswMonFlt;aswMonFlt;c:\windows\system32\drivers\aswMonFlt.sys [x]
    S2 ePowerSvc;Acer ePower Service;c:\program files\eMachines\eMachines Power Management\ePowerSvc.exe [2009-09-30 844320]
    S2 Greg_Service;GRegService;c:\program files (x86)\eMachines\Registration\GregHSRW.exe [2009-08-28 1150496]
    S2 ISWKL;ZoneAlarm Toolbar ISWKL;c:\program files\CheckPoint\ZAForceField\ISWKL.sys [2010-05-26 33008]
    S2 IswSvc;ZoneAlarm Toolbar IswSvc;c:\program files\CheckPoint\ZAForceField\IswSvc.exe [2010-05-26 823272]
    S2 NTISchedulerSvc;NTI Backup Now 5 Scheduler Service;c:\program files (x86)\NewTech Infosystems\NTI Backup Now 5\SchedulerSvc.exe [2009-06-18 144640]
    S2 Secunia PSI Agent;Secunia PSI Agent;c:\program files (x86)\Secunia\PSI\PSIA.exe [2011-04-19 993848]
    S2 Secunia Update Agent;Secunia Update Agent;c:\program files (x86)\Secunia\PSI\sua.exe [2011-04-19 399416]
    S2 Updater Service;Updater Service;c:\program files\eMachines\eMachines Updater\UpdaterService.exe [2009-07-04 240160]
    S3 L1C;NDIS Miniport Driver for Atheros AR8131/AR8132 PCI-E Ethernet Controller (NDIS 6.20);c:\windows\system32\DRIVERS\L1C62x64.sys [x]
    S3 Point64;Microsoft IntelliPoint Filter Driver;c:\windows\system32\DRIVERS\point64.sys [x]
    S3 PSI;PSI;c:\windows\system32\DRIVERS\psi_mf.sys [x]
    S3 SaiH5F0D;SaiH5F0D;c:\windows\system32\DRIVERS\SaiH5F0D.sys [x]
    S3 SaiU5F0D;SaiU5F0D;c:\windows\system32\DRIVERS\SaiU5F0D.sys [x]
    [HKEY_LOCAL_MACHINE\software\wow6432node\microsoft\windows nt\currentversion\svchost]
    nosGetPlusHelper REG_MULTI_SZ nosGetPlusHelper
    2011-10-31 c:\windows\Tasks\GoogleUpdateTaskMachineCore.job
    - c:\program files (x86)\Google\Update\GoogleUpdate.exe [2010-03-13 04:02]
    2011-10-31 c:\windows\Tasks\GoogleUpdateTaskMachineUA.job
    --------- x86-64 -----------
    [HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverlayidentifiers\00avast]
    @= "{472083B0-C522-11CF-8763-00608CC02F24} "
    [HKEY_CLASSES_ROOT\CLSID\{472083B0-C522-11CF-8763-00608CC02F24}]
    2011-09-06 20:45 134384 ----a-w- c:\program files\Alwil Software\Avast5\ashShA64.dll
    "IAAnotif "= "c:\program files (x86)\Intel\Intel Matrix Storage Manager\iaanotif.exe" [2009-10-13 186904]
    "RtHDVCpl "= "c:\program files\Realtek\Audio\HDA\RAVCpl64.exe" [2009-07-28 7982112]
    "Acer ePower Management "= "c:\program files\eMachines\eMachines Power Management\ePowerTray.exe" [2009-09-30 823840]
    "OOTag "= "c:\windows\oobeoffer\oobeoffer\ootag.exe" [2009-09-28 23072]
    "ISW "= "c:\program files\CheckPoint\ZAForceField\ForceField.exe" [2010-05-26 1116136]
    "IntelliPoint "= "c:\program files\Microsoft IntelliPoint\ipoint.exe" [2010-07-21 2327952]
    "IgfxTray "= "c:\windows\system32\igfxtray.exe" [2009-09-02 159232]
    "HotKeysCmds "= "c:\windows\system32\hkcmd.exe" [2009-09-02 380928]
    "Persistence "= "c:\windows\system32\igfxpers.exe" [2009-09-02 358912]
    "ProfilerU "= "c:\program files\Saitek\SD6\Software\ProfilerU.exe" [2009-06-03 357888]
    "SaiMfd "= "c:\program files\Saitek\SD6\Software\SaiMfd.exe" [2009-06-03 194560]
    uLocal Page = c:\windows\system32\blank.htm
    mLocal Page = c:\windows\SysWOW64\blank.htm
    IE: E&xport to Microsoft Excel - c:\progra~2\MICROS~1\Office12\EXCEL.EXE/3000
    IE: Google Sidewiki... - c:\program files (x86)\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_7461B1589E8B4FB7.dll/cmsidewiki.html
    FF - ProfilePath - c:\users\walmart\AppData\Roaming\Mozilla\Firefox\Profiles\obavtsyv.default\
    WebBrowser-{66F2E20D-0DA8-4C11-A9C8-DD8477B88ACD} - (no file)
    WebBrowser-{3948072D-28FE-4206-9F7F-2AFF92B24679} - (no file)
    HKLM-Run-SynTPEnh - c:\program files (x86)\Synaptics\SynTP\SynTPEnh.exe
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}]
    @Denied: (A 2) (Everyone)
    @= "FlashBroker "
    "LocalizedString "= "@c:\\Windows\\SysWOW64\\Macromed\\Flash\\FlashUtil10v_ActiveX.exe,-101 "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}\Elevation]
    "Enabled "=dword:00000001
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}\LocalServer32]
    @= "c:\\Windows\\SysWOW64\\Macromed\\Flash\\FlashUtil10v_ActiveX.exe "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}\TypeLib]
    @= "{FAB3E735-69C7-453B-A446-B6823C6DF1C9} "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}]
    @= "Shockwave Flash Object "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\InprocServer32]
    @= "c:\\Windows\\SysWOW64\\Macromed\\Flash\\Flash10v.ocx "
    "ThreadingModel "= "Apartment "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\MiscStatus]
    @= "0 "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\ProgID]
    @= "ShockwaveFlash.ShockwaveFlash.10 "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\ToolboxBitmap32]
    @= "c:\\Windows\\SysWOW64\\Macromed\\Flash\\Flash10v.ocx, 1 "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\TypeLib]
    @= "{D27CDB6B-AE6D-11cf-96B8-444553540000} "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\Version]
    @= "1.0 "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\VersionIndependentProgID]
    @= "ShockwaveFlash.ShockwaveFlash "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}]
    @= "Macromedia Flash Factory Object "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\InprocServer32]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\ProgID]
    @= "FlashFactory.FlashFactory.1 "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\ToolboxBitmap32]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\TypeLib]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\Version]
    @= "1.0 "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\VersionIndependentProgID]
    @= "FlashFactory.FlashFactory "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\Interface\{E3F2C3CB-5EB8-4A04-B22C-7E3B4B6AF30F}]
    @= "IFlashBroker4 "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\Interface\{E3F2C3CB-5EB8-4A04-B22C-7E3B4B6AF30F}\ProxyStubClsid32]
    @= "{00020424-0000-0000-C000-000000000046} "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\Interface\{E3F2C3CB-5EB8-4A04-B22C-7E3B4B6AF30F}\TypeLib]
    "Version "= "1.0 "
    [HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\PCW\Security]
    @Denied: (Full) (Everyone)
    ------------------------ Other Running Processes ------------------------
    c:\program files\Alwil Software\Avast5\AvastSvc.exe
    c:\program files (x86)\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
    c:\program files (x86)\Bonjour\mDNSResponder.exe
    c:\program files (x86)\Intel\Intel Matrix Storage Manager\IAANTMon.exe
    Completion time: 2011-10-31 18:19:48 - machine was rebooted
    ComboFix-quarantined-files.txt 2011-10-31 22:19
    Pre-Run: 162,027,008,000 bytes free
    Post-Run: 161,877,389,312 bytes free
    - - End Of File - - B07E81AE205CF335B10026F864BDE44E
  14. 2011/10/31
    All clean.
    1. Download Security Check from HERE, and save it to your Desktop.
    • Double-click SecurityCheck.exe
    • Follow the onscreen instructions inside of the black box.
    • A Notepad document should open automatically called checkup.txt; please post the contents of that document.
      NOTE SecurityCheck may produce some false warning(s), so leave the results reading to me.
    2. Download Temp File Cleaner (TFC)
    • Double click on TFC.exe to run the program.
    • Click on Start button to begin cleaning process.
    • TFC will close all running programs, and it may ask you to restart computer.
    3. Please run a free online scan with the ESET Online Scanner
    • Disable your antivirus program
    • Tick the box next to YES, I accept the Terms of Use
    • Click Start
    • Accept any security warnings from your browser.
    • Check Scan archives
    • Click Start
    • ESET will then download updates for itself, install itself, and begin scanning your computer. Please be patient as this can take some time.
    • When the scan completes, click on List of found threats
    • Click on Export to text file , and save the file to your desktop using a unique name, such as ESETScan. Include the contents of this report in your next reply.
    • NOTE. If Eset won't find any threats, it won't produce any log.
  15. 2011/11/03
    Forsaken Knight
    Results of screen317's Security Check version 0.99.24
    Windows 7 x64 (UAC is enabled)
    Internet Explorer 9
    Antivirus/Firewall Check:
    Windows Firewall Disabled!
    ZoneAlarm
    WMI entry may not exist for antivirus; attempting automatic update.
    Anti-malware/Other Utilities Check:
    Out of date Java installed!
    Mozilla Firefox (x86 en-US..)
    Process Check:
    objlist.exe by Laurent
    Alwil Software Avast5 AvastSvc.exe
    Alwil Software Avast5 AvastUI.exe
    Zone Labs ZoneAlarm zlclient.exe
    ``````````End of Log````````````
  16. 2011/11/03
    You can safely uninstall McAfee Security Scan Plus, typical foistware.
    1. Update your Java version here: http://www.java.com/en/download/installed.jsp
    2. Now, we need to remove old Java version and its remnants...
    Download JavaRa to your desktop and unzip it to its own folder
    • Accept any prompts.
  17. 2011/11/03
    Forsaken Knight
    Forsaken Knight Well-Known Member Thread Starter
    1. What is "foistware "?
    2. How do I get rid of mcafee security scan plus? Please explain.
    3. I still can not install malwarebytes anti-virus. I would like help in fixing this.
    4. I can not update via the windows update window. I would like help in fixing this.
    5. I still have problems in running videos like the ones on www.youtube.com and such. Where the video will start to play, and then just stop, but the downloading still continues. The only thing I see is the circle loop that shows that something is happening, but nothing ever does. I have to constantly right click on the video, click on "stop downloading" and press the play button to reactivate the video to play and thus, recontinue the download. I have to repeat this several times. I would like help in fixing this.
    That should sum up what is left that has yet to be fully set as resolved. Oh, I did the rest of your instructions as well. I gotta get off right after I post this, so, I'll post that online scan tomarrow.
    Please, I would very much like your assistance in fixing the other issues I have brought up in this thread which have yet to be fully resolved. Please continue, when you have the time of course, to assist me upon such matters.
    Thank you for your help thus far. I hope that I may continue to attain help from you in regards to issues affecting my pc/laptop.
  18. 2011/11/03
    1. A program which installs without your knowledge.
    2. Start>Control Panel>Programs & Features.
    3. Uninstall Malwarebytes' Anti-Malware using Add/Remove programs in the control panel.
    I still need you to complete all other steps from my previous replies.
  19. 2011/11/07
    Forsaken Knight
    Forsaken Knight
    I uninstalled the mcafee as you stated. I didn't like it, and I was not about to buy the product any time soon. I got no money to spend on such a program.
    I tried as you stated in point 3, but it was the same as before. The program showed the same issues, and if I try to download the program again, after the scan from the download, it won't let me save or run it. Why this is, I do not know.
  21. 2011/11/07
    I suggest you ask a question at MBAM forum: http://forums.malwarebytes.org/
    You may want to provide a link to this topic so they can see your computer is clean.
    Your computer is clean [​IMG]
    1. We need to reset system restore to prevent your computer from being accidentally reinfected by using some old restore point(s). We'll create fresh, clean restore point, using following OTL script:
    Run OTL
    • Under the Custom Scans/Fixes box at the bottom, paste in the following:
    :OTL
    :Commands
    [purity]
    [emptytemp]
    [EMPTYFLASH]
    [CLEARALLRESTOREPOINTS]
    [Reboot]
    • Post resulting log.
    2. Now, we'll remove all tools, we used during our cleaning process
    Clean up with OTL:
    • Double-click OTL.exe to start the program.
    • Close all other programs apart from OTL as this step will require a reboot
    • On the OTL main screen, press the CLEANUP button
    • Say Yes to the prompt and then allow the program to reboot your computer.
    3. Make sure, Windows Updates are current.
    4. If any Trojan was listed among your infection(s), make sure, you change all of your on-line important passwords (bank account(s), secured web sites, etc.) immediately!
    7. Run Temporary File Cleaner (TFC) weekly.
    10. (Windows XP only) Run defrag at your convenience.
    11. When installing\updating ANY program, make sure you always select "Custom " installation, so you can UN-check any possible "drive-by-install" (foistware), like toolbars etc., which may try to install along with the legitimate program. Do NOT click "Next" button without looking at any given page.
    12. Read How did I get infected?, With steps so it does not happen again!: http://www.bleepingcomputer.com/forums/topic2520.html
    13. Please, let me know, how your computer is doing.
