Checking after spyware removal
Discussion in 'Malware and Virus Removal Archive' started by ozmart2004, 2004/12/08.
  1. 2004/12/08
    ozmart2004
    ozmart2004 Inactive Thread Starter
    I had a nasty addware toolbar (together with a bunch of trojans) on my machine earlier today. I cleaned it out with Ad Aware, Spybot and Trojan Hunter, plus I uninstalled the toolbar. I also cleaned out the temp folder and looked in the registry and got rid of a couple of things.
    Last couple of re-boots I noticed that a running process/app called something like "Hidden shell" (it only flashes up quicly) gets shutdown. I can't find anything on it, but I ran a little utilty called 'Startup List" and I say this one thing that looks a bit odd. There is no INI section for a few things. Can anyone tell me if this is normal or not?:
    Otherwise I think its clear now, but would like to make sure!
    Thks
    Martin
    PS Below is the full text of startupist
  2. 2004/12/08
    surferdude2
    surferdude2 Inactive
    Not to worry, here's mine:
    I would suggest that you get SpywareBlaster to keep the meanies off your drive in the first place. It runs seamlessly and silently to block malwares from coming aboard. Your only obligation is to update it occasionally. The current database contains 3244 item it protects against.
    ozmart2004
    OK, thks a lot. :)
  5. 2004/12/08
    just saw surferdude2's reply. Gonna post my comments anyway but you can certainly trust what he says
    Depends on how your system got to the OS version is has today. If a fresh load of XP on a clean drive, I'm really surprised to see quite a few of those entries in the file at all. If an upgrade from an earlier OS version that actually used system.ini to operate the OS, they are probaly just items that weren't needed any longer.
    From looking at your startup stuff I do see a couple of things worth mention though.
    The sun java version you have is way out of date and you need to upgrade to the newest. Lots of security improvements.
    XP does not need, does not benefit from, and can be made less stable by products like memturbo. XP handles the memory issues nicely where as some earlier OS versions didn't. I'd suggest getting rid of the app.
    If you'd like a 2nd opinion on how well your cleaning went, a log from the current version of Hijackthis would let us take a good look.
