chassis fan and thermostat connector
Discussion in 'PC Hardware' started by gghartman, 2004/09/27.
  1. 2004/09/27
    gghartman
    Am putting a 80mm chassis fan in a system with a biostar m7viq system board. Having trouble finding the 3 pin connector on the board for the thermostat wire from the chassis fan. Only 3 pin I can find is the wake on lan. Anybody have an idea or is this wire not really needed.
  2. 2004/09/27
    Paul
    Paul Inactive
    I'm not familiar with that board, but a suggestion is to grab a converter cable and tap straight into a spare output from the PSU. Checking that voltage requirements are met! My side fan and top blower fan were prewired to connect straight to a spare PSU outlet complete with piggyback connectors to allow other drives to be connected as well.
    Paul,
    markp62
    markp62 Geek Member Alumni
    While the adaptor shown in Mattman's will actually have 2 wires going to the fan, it will work. The third wire [yellow] is for RPM monitoring, not needed for fan operation.
  6. 2004/09/28
    gghartman
    The fan has a connector that allows me to connect the power part of the fan to the psu but the other is a yellow one wire connected to a 3 pin plug.
    The fan works just fine. Based on Markp62 I guess the yellow wire is not needed.
    Thanks.
