Changing system name in xp home
Discussion in 'Windows XP' started by Bimmer Guy, 2006/08/15.
  1. 2006/08/15
    Bimmer Guy
    Bimmer Guy Well-Known Member Thread Starter
    I had someone set up this computer and they put their initals for the system name. Is there a way to change to my name?
    thanks
    xp home sp2
  2. 2006/08/16
    mailman Lifetime Subscription
    mailman Geek Member
    Hi, Bimmer Guy. :)
    Perhps you're referring to the following location:
    • Open "My Computer" (may be located in your "Start" menu or an icon on your desktop).
    • Right-click anywhere on the empty part of the My Computer window.
    • Select Properties.
      (This will open your "System Properties" window.)
    • Select the "Computer Name" tab.
    • Click the "Change" button.
    • Edit the "Computer name:" field.
    EDIT: Here's a quicker (but perhaps harder to remember unless you use it often) way to get to the "System Properties" window:
    Hold down your Windows Key and press the Pause Key. :)
    Please let us know if this works for you.
    Bimmer Guy
    Hi mailman, I replied too soon. Your suggestion fixed the query I had. Thanks very much.
    ps That quick little edit trick is one I will remember. Saves time:)
