changing dialup settings
Discussion in 'Windows XP' started by dolphin, 2004/04/10.
  1. 2004/04/10
    dolphin
    dolphin Well-Known Member Thread Starter
    First , thanks for all your help in the past!
    I have DSL and have set it to NEVER dial a connection. Seems like daily I have go in and change the setting back because it keeps changing to dail whenever a network connection not present. I do not do this! Someone has told me if I use any messengers at all XP will do this automatically. Any clues here?
    Sure am tired of always having to change the setting and getting that old pop up, dialup screen.:mad:
  2. 2004/04/10
    noahdfear
    noahdfear Inactive
    If it were my computer, I would;
    1. check startup tab in msconfig for any third party apps. that require an internet connection (real player, quicktime, weatherbug, AV autoupdate, ISP software, etc.)
    2. eliminate possible trojan wanting to make sure PC is connected whenever it's running with some online virus scans
    dolphin
    YAHOO :D Thanks again ! Real Player was the culprit!
  5. 2004/04/10
    noahdfear
    noahdfear Inactive
    Glad you found it. Thanks for posting back! :)
