Changing AGP Speed
Discussion in 'PC Hardware' started by Johanna, 2004/06/04.
  1. 2004/06/04
    Johanna
    Johanna Inactive Alumni Thread Starter
    How do I enable 4X AGP on this system?
    Chipset Properties
    Motherboard Chipset SiS 735
    CAS Latency 3T
    RAS To CAS Delay 3T
    RAS Precharge 4T
    AGP Properties
    AGP Version 2.00
    AGP Status Enabled
    AGP Aperture Size 64 MB
    Supported AGP Speeds 1x, 2x, 4x
    Current AGP Speed 2x
    Fast-Write Not Supported
    Side Band Addressing Supported, Enabled
    Chipset Manufacturer
    Company Name Silicon Integrated Systems Corporation
    Product Information http://www.sis.com/products/index.htm#chipsets
    Driver Download http://download.sis.com
    Problems & Suggestions
    Problem Current AGP speed is lower than maximum supported. This may cause performance penalty.
    TIA
    Johanna
  2. 2004/06/04
    Paul
    Paul Inactive
    Obviously Johanna, you've gone to the download site http://download.sis.com/ and updated the various drivers pertaining to the system, in particular the AGP(GART) v1.17E driver and checked that the card does support 4x.
    Check for any information on an available BIOS update to see if there is a fix for a known problem.
    Paul,
    Hi Johanna,
    Looked in the motherboard manual for K7S5A (PCB 1.X) and could not find settings for AGP or jumpers. It may be that the BIOS automatically detects the AGP capability of the graphics card you are using. Can you pls supply the make and model of the graphics card? It will depend on whether the graphics card is 4x or only 2x.
    The one setting in the BIOS that may be applicable is "load best performance ", although there does seem to be any AGP setting to load.
  5. 2004/06/06
    Johanna
    BIOS states 4X is enabled.
    Device Description Device Type
    ATI RV100 DDR Video Adapter
    ATI RV100 DDR 3D Accelerator
    Thanks, guys, I don't understand this one.
    Johanna
  6. 2004/06/06
    Triger
    Triger Inactive
    Suggestion
    Johanna ...
    For what it's worth, you might want to try emailing ATI tech support....I have had several occasions where I contacted them and they where very very helpful each and every time and always contacted me a second time wanting to know if the issue was resolved ...(matter of fact, that is the main reason I buy their products)
    Cheers
    Jake
  7. 2004/06/07
    Triger's suggestion sounds good, always a change when you get a reply :)
    My search couldn't find an "ATI RV100 DDR Video Adapter ", as such. Where are you reading this? What is Device Manager's description? Is that what Aida32 says it is?
    You may have the wrong drivers installed.
    Is the video onboard? (Not from the manual I looked at.)
    May have to physically remove the card and identify it from the markings. (Unless you have some specifications, manuals, etc, already).
    ATI may be the way to go, but you may have to armed with a few details.
    PS I wondered about running DXDIAG, although it does not include info on the AGP rating, but could give information on your drivers.
  8. 2004/06/07
    Johanna
    Thanks, guys. It was an older driver holding back the vid card. I had no luck finding the right driver on the net, but XP updated it for me in Device Mgr. from version 2 to 5!!! I stumbled on this trying to correct another problem- HEAT- so, if you'll excuse me, I'm going to go put the processor in the freezer, now, for lack of a better idea! :D
    Johanna
