Chaining to web from OE
Discussion in 'Internet Explorer & Microsoft Edge' started by tenbob, 2004/05/07.
  1. 2004/05/07
    tenbob
    tenbob Inactive Thread Starter
    When I click on a URL in OE, I get to Internet Explorer. However, I use MyIE which is a front end for IE with some advantages.
    Where can I change the OE option? I guess it is the same place I would use to chain to Netscape, Mozilla or the like.
  2. 2004/05/07
    This is a "file association" issue that can be changed in Windows Folder Options->File Types.
    I don't have my notes here to be able to tell you which one to change..
    tenbob
    Sounded right so I went thru the entire list of filetypes and changed all the ones showing the IE icon to MyIE. Didn't make any difference. Still came up in straight IE.
  5. 2004/05/07
    brett
    brett Inactive Alumni
    Is MyIE set as your default browser?
  6. 2004/05/08
    tenbob
    Head hiding time :eek: I never thought to check that. Now I set it as default and OE chained to MyIE. Sheesh !!!!! :D
  7. 2004/05/08
    brett
    I'm glad that the solution was so easy :D
