ChainCast
Discussion in 'Other PC Software' started by MinnesotaMike, 2003/08/05.
  1. 2003/08/05
    MinnesotaMike
    MinnesotaMike Geek Member Thread Starter
    Question. My wife is trying to listen to a radio station over the Internet. The problem is that it says that she needs a plug-in called ChainCast ActiveX. A search on Google didn't show much about it. One listing says that it is a spyware program.
    Has anyone used this plug-in or know anything about it? Any info is appreciated!
    Mike
  2. 2003/08/06
    picard
    picard Inactive
    MinnesotaMike
    picard,
    Thanks for the info! Having an opinion from somebody that actually has it is better then just reading about it. I thank you also for the links. I will read through them and keep your reply handy when I give it a try.
    By the way, are you using Netscape or Internet Explorer?
    Mike
  5. 2003/08/06
    picard
    picard Inactive
    I'm using IE6
  6. 2003/08/06
    MinnesotaMike
    Well, if it doesn't work in Netscape, I'll just put it in IE. Thanks.
    Mike
  7. 2003/08/06
    picard
    picard Inactive
    Found this on the ChainCast web site.
    Netscape versions 4.08~4.7* are supported, Netscape 6.* is currently not supported.
