cda engine 0400.dll
Discussion in 'Malware and Virus Removal Archive' started by dolphin, 2004/11/29.
  1. 2004/11/29
    dolphin
    dolphin Well-Known Member Thread Starter
    Can anyone tell me what this is? When I logon it tells me that wild tangent\apps\CDA\CDA engine0400.dll is missing.
    I have cleared all the wild tangent items through spybot and Ad Aware.
    I just want to get rid of the dang screen that keeps telling me it is missing.
    I tried to search windows explorer for CDA but can't seem to locate anything.
    Any help would be greatly appreciated! :)
  2. 2004/11/30
    Paul
    Paul Inactive
    dolphin, I found this. Seemed to work for someone else with same problem, and I quote, so can't varify this fix for your problem. ;)
    "Go to START > Settings > Control Panel
    Double click Add/Remove Programs, Select WildTangent ,
    Click uninstall or add/remove, follow the on screen instructions.
    Open the registry editor (Click Start > Run, type regedit). Locate the following key:
    HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run
    In the right pane, find and delete the following entries ( if they exists):
    WildTangent CDA
    RUNDLL32.exe "C:\Program Files\WildTangent\Apps\CDA\cdaEngine0400.dll ",cdaEngineMain
    Follow his steps - now here's the catch i found
    Make sure to exit directly out of the registry editor once you delete the file. Don't browse to other folders or it will stay there. Reboot and the computer will save the current settings. Next run, it should be clear. Hope this helps. "
    A bit of googling found some info as well...
    http://www.google.com.au/search?hl=en&q=wild+tangent&meta=
    Paul,
    dolphin
    Okay, I still can't find anything in regedit that says anything about CDA engine0400.dll.
    Any other suggestions?
  5. 2004/12/09
    Pretty much the only possible places would be
    Registry in the run section
    Registry in the runonce section
    system.ini run entry
    win.ini run entry
    If you have msconfig (depends on your OS), you could check there for startup entries by that name and uncheck any you found.
