CD Drive [ejects cd without reading]
Discussion in 'PC Hardware' started by vpanchapakesan, 2007/02/15.
  1. 2007/02/15
    vpanchapakesan
    vpanchapakesan Inactive Thread Starter
    Whenever I insert a CD in my CD drive, the indicator light blinks and after some time the cd comes out automatically without reading. I tried several times but could not get the CD read.
  2. 2007/02/15
    charlesvar
    charlesvar Inactive Alumni
    Hello vpanchapakesan,
    Lets see what Device manager shows.
    Right click My Computer
    Properties
    Hardware tab
    Device Manager
    Expand (click +) DVD/CD ROM Drives
    Is the drive there? If so, is there any warning (yellow shield)?
    Right click on drive > properties - what does the device status say?
    I've added to your thread title for more detail.
    Regards - Charles
    charlesvar
    Recieved an email from vpanchapakesan:
    I'll anser here and please keep your reponses here in this thread, click on the Post Reply button:
    Try a basic remedy: go back into DM and right click on the ROM drive and Uninststall. Then re boot, Windows will redetect the drive.
    Regards - Charles
  5. 2007/02/15
    You don't say, but have you tried several types/brands of disk. It could not be that the disk is a DVD and the drive only reads CDs?
    I suggest you test the drive. Go into the Configuration/Startup settings when you first startup. Try inserting a CD there. If it stays in the drive, see if it is ejected when you boot into Windows. If it ejects when you are in the startup settings the drive is probably faulty (although check using several types of disk).
