Windows Vista Can't use USB jump drive or card reader
Discussion in 'Legacy Windows' started by mrtep, 2007/07/03.
  1. 2007/07/03
    mrtep
    mrtep Inactive Thread Starter
    I am using Windows Vista Ultimate and I cannot use any USB card readers or jump drives. It tells me there is a problem loading the driver. There are no drivers for jump drives at the manufacturers web sites. I have a Lexar fire fly 4 gig jump drive. Any suggestions?
  2. 2007/07/04
    Hi,
    Have you installed Vista drivers for your chipset? USB Controller drivers will be bundled with those. The drivers should be available at the computer/motherboard manufacturer's website, if not, you can try looking up the model of your chipset at the chipset manufacturer's website.
