Resolved Cant see XP Machine on Home Network
Discussion in 'Networking (Hardware & Software)' started by Whacker, 2012/08/03.
  1. 2012/08/03
    Whacker
    Whacker Well-Known Member Thread Starter
    Hi All, I have a Linksys Wirless G router I want to use as a Hub, so I have given it the new ip address of
    192.168.1.100 & switched off DHCP, NAT, & wireless access but left the sid broadcastig.
    I have a 30mtr cat5 cable running from the Linksys port 4 back to the cisco gateway port 4.
    I have the 2 other pc's with static IP's 192.168.1.25 (running XP 32 Bit) & 26 (running win 7 64bit) connected to
    ports 3 & 2 with patch cables to the Linksys.
    My main machine is getting it's IP address 192.168.1.11 (running Win 7 64bit) direct from the cisco box on DHCP via
    a 30mtr run of cat5 cable.
    My main Router is a Cisco Model DPC/EPC2425 is set to 192.168.1.1 and is the gateway.
    I can access the internet from all machines on my home network and all machines can be ping'ed scussfully.
    All PC's are in the same WORKGROUP.
    My Problem is this:
    Why can I see 192.168.25 XP machine on my network?
    All machines c:\ drives are set to shared as is the printer.
    I've tried using a DHCP address no luck, I've tried to map a drive no luck.
    Any help would be appericated.
    Thanks Whacker.
  2. 2012/08/03
    Whacker
    I turned of the SID broadcast and problem was solved???? S T R A N G E
