Can't Log On Part 2 - XP Installation Problem (Sleep mode?!)
Discussion in 'Windows XP' started by Tok, 2004/09/28.
  1. 2004/09/28
    Tok
    Tok Inactive Thread Starter
    Well, I recently decided to boot from my CD after an 'Endless Boot Error'. Once I'd loaded all the files and restarted I came across the GUI Installation. When I insert the CD, it starts the installation and says 39 minutes remaining
    Once it's installed the 'Devices' and is at 34 minutes remaining, the screen goes black and my monitor says 'Going into Sleep Mode' (or something similar). The computer is still running and I've tried pressing EVERY key, Ctrl+Alt+Del and switching the monitor on and off. The computer is still running (you can hear it) but the screen is blank and it doesn't do anything.
    When I restarted, I tried clicking the mouse permanently (to stop Sleep mode maybe?) and it didn't work. Once it enters sleep mode I have to restart and then the installation starts again.
    Please Help!!!
    Tok,
  2. 2004/09/28
    Windows XP Setup Stops Responding During the "Collecting Information" Portion of Setup
    http://support.microsoft.com/default.aspx?scid=kb;en-us;822967&Product=winxp
    Windows XP Setup Stops Responding (Hangs) During the "Preparing Installation" Phase
    http://support.microsoft.com/default.aspx?scid=kb;en-us;315323&Product=winxp
    Setup Stops Responding with 34 Minutes Remaining
    http://support.microsoft.com/default.aspx?scid=kb;en-us;828267&Product=winxp
    Computer Stops Responding When You Install Windows XP on a Computer with an i815 Chip Set Motherboard
    http://support.microsoft.com/default.aspx?scid=kb;en-us;282195&Product=winxp
    Setup Stops Responding or Displays an Unrecoverable Error Message
    http://support.microsoft.com/default.aspx?scid=kb;en-us;811267&Product=winxp
    Windows XP SP1 Installation Stops Responding with About 34 Minutes Remaining
    http://support.microsoft.com/default.aspx?scid=kb;en-us;815319&Product=winxp
    Windows XP Does Not Respond at "Setup Is Starting Windows XP" Message
    http://support.microsoft.com/default.aspx?scid=kb;en-us;310760&Product=winxp
    Resources for troubleshooting startup problems in Windows XP
    http://support.microsoft.com/default.aspx?scid=kb;en-us;308041&Product=winxp
