Can't keep cookies with IE 6.0
Discussion in 'Internet Explorer & Microsoft Edge' started by OLDSALTY, 2005/04/25.
  1. 2005/04/25
    OLDSALTY Lifetime Subscription
    OLDSALTY Inactive Thread Starter
    I use Google as a home page. I have to constantly save my preferences because Google says my cookies are not set right. I have followed their instructions to set them right and they still will not keep. Mozilla Firefox cookies work work fine. Any ideas how to tweak IE??
  2. 2005/04/25
    Welshjim
    Welshjim Inactive
    OLDSALTY--Can you be a little more specific about that message that says the cookies are not set right? Do you have www.google.com in your Restricted Sites? What are the settings for cookies in IETools|Internet Options|Privacy tab and Privacy tab|Advanced?
    No I do not.
    Medium
    Nothing is checked.
    I snapped the message that Google is giving me.
  5. 2005/04/25
    Welshjim
    Welshjim Inactive
    OLDSALTY--The message says "your cookies seem to be disabled ". Taking that at face value, you/we have to figure out what is disabling them. For example, do you use any cookie management program?
    What are you doing when you get that message?
    What are the "preferences" which are changing?
    When you say "I use Google as a home page ", what Google site are you using?
    I do not use Google as a HomePage so have no direct experience. However, I use www.google.com and google EMail all the time without problem. And my Privacy setting is at Medium High.
  6. 2005/04/25
    No
    Just opening IE to www.google.com
    all of them.
    www.google.com
  7. 2005/04/26
    Welshjim
    Welshjim Inactive
    OLDSALTY--On the Google Preferences page, presume you are clicking Save Preferences at the bottom right before exiting.
    Otherwise, you got me. As mentioned it seems, if the message is correct, that something is disabling cookies, but I have mentioned all the reasons I can think of.
    Is this the only site giving this problem?
  8. 2005/04/26
    I checked the firewall and found 2 entries for google. I had X (block) in the 3rd party comumn. I put a check (allow) and everything is ok not. Thanks for using up some of those brain cells.
  9. 2005/04/26
    Welshjim
    Welshjim Inactive
    OLDSALTY--Thanks for posting back with the fix. Got to remember the firewall!! Although the error message was misleading. :)
  10. 2005/04/27
    Well That Only Worked For That Session. Now It Is Telling Me I Don't Have Cookies Ebabled Again.
