Cant connect to ethernet or wireless?
Discussion in 'Windows XP' started by JohnDoe, 2010/11/10.
  1. 2010/11/10
    JohnDoe
    JohnDoe Inactive Thread Starter
    Hello i recently clean installed xp professional after having troubles with infections. Since the clean install i cannot connect to the internet from both methods, I have an ASUS laptop but not sure which model any help would be appreciated
  2. 2010/11/10
    After you installed Windows did you install the Chipset and other drivers for the pc? You either got a cd for them or you can get em from ASUS's web site.
    JohnDoe
    No i did not, unfortunately i had to download a clean install.. Where can i get these drivers from and how could i transfer them from my computer to my laptop? thanks in advance!
  5. 2010/11/10
    You can download them from ASUS's web site....Copy em to a flash drive or cd.
    JohnDoe likes this.
  6. 2010/11/11
    JohnDoe
    Ok i downloaded a few of them but it still hasn't enabled wireless or allow me to use an ethernet cable! What are these "chip sets" ?
  7. 2010/11/11
    Chipset drivers give support for the core functions of the motherboard.
    Did you download and install the network drivers for your particulat asus?
    What model is this comp?
  8. 2010/11/11
    JohnDoe
    i downloaded a few of them like the wireless, Lan, Modem drivers but there doesn't seem to be a difference, i have an ASUS A7Cc, if i downloaded the VGA driver would that make a diffrence as it seems to be the largest file size
  9. 2010/11/11
    VGA is the video driver. It won't affect networking but yes, you should install it.
