Can't connect to a specific web site
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by xseedman, 2011/03/03.
  1. 2011/03/03
    xseedman
    xseedman Inactive Thread Starter
    I have recently experienced a problem on one of my computers. There is a specific web site that I cannot access (www.vistaprint.com). I have a home network (Ethernet wired) and the other 2 computers on that network can access the site.
    On the computer where I have experienced the problem, I have both Firefox and IE8 installed. Neither browser can access the site. I get the following indications:
    Firefox – page opens that advises “Unable to connect” “Firefox can’t establish a connection to the server at www.vistaprint.com”
    IE8 – page opens that displays “unable to connect”. When the diagnose connection problem button is clicked the message is “The remote device won’t accept the connection”.
    Since this occurs only on the one computer, I concluded that the problem was related to something on that computer, and since both browsers are unable to connect, it must not be specific to a browser. Specifics about that computer:
    Windows 7 pro without SP1 installed
    Microsoft Firewall and Microsoft Security Essentials are only active security programs used.
    I have checked Internet Options in the Control Panel. Security settings are medium on all except Restricted Sites; Privacy is set at medium with popup blocker enabled; There are no parental controls used; Connections – LAN settings – automatically detect settings with no proxy server; Advanced settings are too numerous to mention at this time.
    Searches I do on problems similar to this advise checking settings in Internet Options.
    At this point I’m “stumped”. An answer or pointing in the direction to finding one would be appreciated.
    George
  2. 2011/03/03
    Z Purple Hippo
    Z Purple Hippo Inactive
    I get a cannot connect page, too.
    xseedman
    Thanks for the repliy.
    I finally figured out that it was a Hosts file problem.
    Apparently Spybot, that I run occasionally to check for malware, added an entry in my Hosts file that pointed to my local IP address. When I edited and Rem'd out that entry, the DNS server found the proper IP address and accessed the site.
  5. 2011/03/03
    i got to it with no problem. I use Spybot also. Do you have TeaTimer enabled?
  6. 2011/03/03
    Westside
    Westside Inactive Alumni
    I, also, have had no problem. I don't have Spybot. The TeaTimer feature of Spybot may be the problem.
  7. 2011/03/03
    xseedman
    I don't have tea timer enabled now, but did some time ago.
    I wonder if that is what caused it?
