Resolved Cannot start from USB
Discussion in 'PC Hardware' started by cspgsl, 2015/09/19.
  1. 2015/09/19
    cspgsl Lifetime Subscription
    cspgsl Geek Member Thread Starter
    I have an ACER E15 laptop that I cannot start from a USB Flashdrive.
    The user attempted to do a refresh on Win 8.1 and it failed. When it starts it immediately goes to a Windows repair attempt but fails.
    I have 8.1 on a flash drive but when I change the boot order to the USB it ignores it and goes to the Windows Boot Manager and then to the repair screen.
    If I attempt to repair from a USB device in the Windows repair options, it restarts and goes to the boot manager again.
    I was thinking that pulling the HDD and wiping it then attempting the USB install might work but I thought I would ask for suggestions first.
  2. 2015/09/19
    Hi cspgsl. If you have already set the USB drive as the first boot device and the laptop isn't booting to it then wiping the drive first and starting over from scratch is a possible solution that you could try.
    Is there an option in the UEFI to enable Legacy boot mode?
    Yes, Legacy is available though not enabled
  5. 2015/09/19
    Try enabling the Legacy boot mode and then set the USB flash drive as the first boot device.
  6. 2015/09/20
    that worked. Win 8.1 is installed and activated.
    Thanks,
  7. 2015/09/20
    Great. Thanks for the update. :)
