Can Seee Nothing On Monitor
Discussion in 'PC Hardware' started by JBU, 2004/05/04.
  1. 2004/05/04
    JBU
    JBU Inactive Thread Starter
    I Switched Pc Off And When I Came Back Again 2 Put It On Nothing !! I Can See Nothing On Mointor...i Tried My Vga Card On Another Comp And It Worked ! Can Some One Please Help Me
    JBU,
  2. 2004/05/04
    JBU - Welcome to the Board :)
    Quite possible that the monitor has died - check it out on the other computer too. Are the power/standby lights lit?
    Moving this to Hardware
    user__11063
    user__11063 Well-Known Member
    I take it that when you say nothing on monitor you don't even see the post screen bootup? As was previously mentioned it most probably is your monitor, however have you checked to make sure that none of your pins on the monitor cable are bent or snapped off, because this could cause the monitor not to work as well. Alternatively plug your monitor into another base unit and if it is not working then you know its the monitor.
  5. 2004/05/07
    JBU - any progress? Posting back helps all of us :)
