Can not display HTTPS:// (S)
Discussion in 'Internet Explorer & Microsoft Edge' started by SVEN, 2005/12/13.
  1. 2005/12/13
    SVEN
    SVEN Well-Known Member Thread Starter
    Hi all,
    I got a new problem. Today when I was logging on to my bank, I got a "The page cannot be displayed" error.
    I checked other web pages, and the only ones I can not access are the ones that start with HTPS://. The regular HTTP:// are fine. What would cause that.
    Any help is appreciated.
    Sven
    SVEN,
  2. 2005/12/13
    McTavish
    McTavish Inactive
    First thoughts would be your firewall or some other security app you have. HTTPS uses a different port to HTTP so your browser needs to be allowed to connect to remote port 443.
    SVEN
    No, thats not it. I turned of my firewall and have the same problem.
    thanks anyways.
    Sven
    SVEN,
    maggie
    maggie Inactive
    Try this
    Click Start, and then click Run.
    In the Open box, type cmd, and then click OK.
    At the command prompt, type the following lines and press ENTER after each line:
    regsvr32 softpub.dll
    regsvr32 wintrust.dll
    regsvr32 initpki.dll
    regsvr32 dssenh.dll
    regsvr32 rsaenh.dll
    regsvr32 gpkcsp.dll
    regsvr32 sccbase.dll
    regsvr32 slbcsp.dll
    regsvr32 cryptdlg.dll
    Click OK when you receive the message that DllRegisterServer in FileName succeeded.
    Type exit to quit Command Prompt
    http://support.microsoft.com/default.aspx?scid=kb3%b[LN]3%B813444
    You'll have to copy and paste the above link.
  6. 2005/12/14
    McTavish
    McTavish Inactive
    SVEN
    Maggie and McTavish.
    Thanks for the link. I will try that tonight.
    Sven
    BTW, Maggie, Your link does not work??
    SVEN,
    #6
  8. 2005/12/14
    Welshjim
    Welshjim Inactive
    SVEN--If the above does not help, what versions of Internet Explorer and Windows are you running?
  9. 2005/12/14
    SVEN
    Success!!
    It worked, I reregistered all the .DLL files and now I can access my bank again.
    Thanks for your help
    Sven
    SVEN,
    #8
  10. 2005/12/14
    maggie
    maggie Inactive
    OK!! I hate those glitches. :D
