Camera>XP Problem
Discussion in 'Windows XP' started by REDDY4IT247, 2005/10/15.
  1. 2005/10/15
    REDDY4IT247
    REDDY4IT247 Inactive Thread Starter
    Pentax *1stDS Digital SLR Camera conected with USB cable to Windows XP PC.
    Windows sees camera as a hard drive in
    "Device Manager" as "PENTAX DIGITAL_CAMERA USB Device"
    and Properties says Working ok,
    but it is not showing in "My Computer "
    window
    so I can't move pictures to PC or download any upgrades to the camera hardware.
    Has anybody any solutions to this problem please? :mad:
  2. 2005/10/15
    hawk22
    hawk22 Geek Member
    Have you tried a USB Card-reader, I find them much better than connecting the Camera.
    hawk22
    WhitPhil
    WhitPhil Inactive
    Can you download using the Pentax Photo Browser software that was included?
  5. 2005/10/15
    skeet6961
    skeet6961 Inactive
    did u install the camera & it's software in accordance w/ the instructions from the maker?
    if it's a USB device connection, u should heed their install instructs since many will not work until u dummy up & do ;)
  6. 2005/10/15
    sparrow
    sparrow Inactive
    Also, when in doubt, try rebooting after attaching.
  7. 2005/10/15
    oshwyn5
    oshwyn5 Inactive
    Is camera turned on? Although some cameras will sense the usb connection and power up the memory card , others require setting the switch on the camera to a specific setting. Others require you to choose the device you are connected to and click okay using the LCD display on the camera.
