calculator
Discussion in 'Legacy Windows' started by burgundy13, 2003/01/15.
  1. 2003/01/15
    burgundy13
    burgundy13 Inactive Thread Starter
    I can not get my computer to add my calculator in the add/remove programs section. I get the following:
    The following error occurred: 'The file was not found'(error#2).
    Setup could not finish opening a file on the source disk.
    Source File: 'C\WINDOWS\OPTIONS\CABS\calc.cnt'
    Destination: 'C\ WINDOWS\HELP\clac.cnt=WIN98_25.CAB
    I have even tried to pull it off my Windows cd, with no luck.
    I have also tried a general clean-up/fix-up in dos, still no luck.
    Any advise would be greatly appreciated.
  2. 2003/01/15
    Calculator should not show up at all in Add-Remove Programs. It should show up in Accesories in Windows SetUp.
    LLDJ
    LLDJ Inactive
    Addind The Calculator
    burgundy,
    to add the calc,
    first insert the win98 cd,
    and go to add/remove programs,
    then go to the "Windows Setup" tab,
    then double-click the accessories,
    and check the calculator button.
    Click Ok and let the computer install it from the cd.
    Congrats, you now have a calc...!
    LLDJ,
    burgundy13
    I have to use C:\windows\options\cabs The only cd i got with my system is a recovery disk. I have tried pulling the file off of both the recovery cd sand out of 'options'. Niether one works. I can go to windows set-up and check the box, but it says that it cannot find the file. Any suggestions?
  6. 2003/01/16
    markp62
    markp62 Geek Member Alumni
    Check your windows\options\cabs folder for these four files; win98_23, win98_25, win98_44 and win98_49 . If you have these, the calc files can be definitely found.
  7. 2003/01/16
    Zephyr
    Zephyr Inactive
    If you have any old Win95 or Win3.1 disks, you can pull it off those. Only two files required, calc.exe and calc.hlp (calc.chm in later versions) and away you go. You probably don't need to worry about the calc.hlp or calc.chm even since it'll run without those.
    It'll run as a stand alone, no installation required. Just put it in your Windows directory or anywhere else on your path.
  8. 2003/01/21
    burgundy13
    I did not find any of those files in my cabs folder, nor could I find any when I did file search. As for the old 95 disk I do not have anything like that. Any other suggestions?
  9. 2003/01/21
    mflynn
    mflynn Inactive
    burgundy13
    Just send me an email at mflynn@lexcominc.net and I will reply, attach and send to you.
    mike
  10. 2003/01/24
    burgundy13
    mflynn,
    I tried several times, the e-mail was rejected by the server. Thanks anyway
  11. 2003/01/24
    mflynn
    mflynn Inactive
    Thanks for telling me! You are the second person to tell me that. I must have a problem I was not aware of.
    Send to my office at phacs@nortstate.net and I will send it from here.
    I will see what is wrong with my email tonight thanks again.
    Mike
  12. 2003/01/29
    burgundy13
    mflynn, tried that address too. Also rejected. Thanks for trying to help
  13. 2003/01/29
    goddez1
    goddez1 Inactive
