Burning 24x in winXP pro
Discussion in 'Windows XP' started by Flue, 2002/05/04.
  1. 2002/05/04
    Flue
    Flue Inactive Thread Starter
    Hi Im having trouble to burn 24x in windows xp both white Nero and Clonecd I got a multi boot system and in win98se it work youst fine, is there a patch or somthing like it to fix the problem so my burnprof dont jump in all the time to save the cd in winXp?
    Best Regards Henrik Elnertz
    Flue,
  2. 2002/05/04
    Zephyr
    Zephyr Inactive
    I know of nothing other than being sure you aren't running anything in the background that might demand some attention away from the disk write. Try killing all apps before doing the burns.
    Good luck.
