Burner Drive and its Id....
Discussion in 'PC Hardware' started by BriGuy2005, 2002/03/03.
  1. 2002/03/03
    BriGuy2005
    BriGuy2005 Inactive Thread Starter
    Well, I was going to burn. I put the cd in and I pushed the button to make it go back in and it went in. But then it came right back out. SO I pressed the button to make it go back in again and it came out. It hasn't gotten back in yet without coming back out. When I click on my drive in MY computer and click explore on it.. it says "this device is not ready ".... So does anyone know what I can do... ? DO i need to reinstall the drive? If so.. how? THanks for your help. I have tried to restart a million times. However my drive (f) has yet to close. Does anyone know what to do?:confused:
  2. 2002/03/07
    Rancher
    Rancher Inactive
    firmware
    Is this a new 24X? Are ya on an AMD proc? Liteon, for examole , has a firmware upgrade for theirs on the web page. I have the 24X & samo prob, not now tho. Try your burners site for new firmware:)
    Gary3072
    Gary3072 Guest
    Burner drive not reading
    I have a similar problem...my drive just wont read any discs at all. It opens and closes but that's it. I had it serviced by HP and they replaced the hard drive, claiming the cdrw read fine. I got it back and it did work, but failed me after a few discs were played.
    Is this a faulty IDE Cable, motherboard, or an incorrect BIOS configuration? BTW= my BIOS revision was done on 9/11/01 but I doubt that has anything to do with it :)
    Any info would be greatly appreciated...
    Thanks!
  5. 2002/04/03
    Gary3072
    Gary3072 Guest
    Also, my drive is a Mitsumi CR-4845TE cdrw.
