Burn-In Concern
Discussion in 'PC Hardware' started by csnudelman, 2002/09/24.
  1. 2002/09/24
    csnudelman
    csnudelman Inactive Thread Starter
    Powering up my new computer for a 72 hour burn-in seemed to go normally. The power light came on steady and stayed on. The HD light came on for a moment and then went out. Two hours into the burn-in we had a momentary loss of household current. My current computer went down and then powered itself up. The new one went down. When I turned it back on the power light acts as it should but now the HD light stays on. Do I have reason for concern?
  2. 2002/09/24
    KenKeith
    KenKeith Inactive
    A power surge could cause a serious problem, but a momentary power loss will or could cause RAM data loss.
    In a manufacturing environment computers were burned-in for 72 hours and maybe that procedure continues. That is not any magic number, but it was a minimum of time for expeditious reasons. You may want to consider a longer time period. Apparently, you know weak components will fail in a short period of time... I almost always leave my computer on with the believe that turning on and off is damaging in the long run.
    Rockster2U
    Rockster2U Geek Member
    I'm another big believer in leaving things running 24/7 - none of them ever get turned off for the night. However, going back to the original question re: hard drive light now acting finicky, I've found that total disconnect from power (and I mean unplugging your computer) can sometimes cure the strangest things. This is true of both printers and CPU's - I recently had a Plextor CDRW that was continually flashing, was no longer recognized, wouldn't respond to pushing eject or selecting eject from a right click - notta, notta - nothing - dead drive. Tried everything I know of to no avail and was going to physically replace the drive. Disconnected everything, includng power cord to install another computer in a relatively tight space next to this machine and rearrange wires. When I plugged this box back in, Plextor drive is working like nothing ever happened. Go figure ....
  5. 2002/09/24
    csnudelman
    Rockster2U, that worked, go figure.
  6. 2002/09/25
    KenKeith
    KenKeith Inactive
    Quote:
    _________________________________________________
    I agree. It is not unlike reversing a two prong plug (both the same size) and that would correct what may have been a polarity problem.
    The only variable involved in this instant case is true grd. Apparently, removing grd. and reconnecting clears out a circuit, but to show a causal relationship to a momentary power loss is a challenge.
