BUGCODE_USB_DRIVER usbuhci.sys PLEASE HELP
Discussion in 'Windows XP' started by bdsilvano, 2007/06/08.
  1. 2007/06/08
    bdsilvano
    bdsilvano Inactive Thread Starter
    Just one week ago I buy my new 160 GB SATA Drive and install it into my old computer. now my computer have 1XIDE ata & 1xSATA drive, but when I try to copy data from IDE to sata im having a Blue Screen Error says BUGCODE_USB_DRIVER. Im Having annoy withi this one as I try to fix this for one week now. firstly I thouth sata have problem because i didnt have any error like this for passed 3 years and when I install only SATA im having now.
    Same goes when I copy Anything from DVD to SATA im having problem same.
    But when I try to copy DVD to IDE no problem. Please help. Im posting my Minidump Log Error.
    Microsoft (R) Windows Debugger Version 6.7.0005.0
    Loading Dump File [C:\Documents and Settings\phoenix\Desktop\Mini060907-05.dmp]
    Symbol search path is: *** Invalid ***
    * Symbol loading may be unreliable without a symbol search path. *
    * Use .symfix to have the debugger choose a symbol path. *
    * After setting your symbol path, use .reload to refresh symbol locations. *
    Executable search path is:
    * Symbols can not be loaded because symbol path is not initialized. *
    * The Symbol Path can be set by: *
    * using the _NT_SYMBOL_PATH environment variable. *
    * using the -y <symbol_path> argument when starting the debugger. *
    * using .sympath and .sympath+ *
    Unable to load image ntoskrnl.exe, Win32 error 0n2
    *** WARNING: Unable to verify timestamp for ntoskrnl.exe
    *** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
    Windows XP Kernel Version 2600 (Service Pack 2) UP Free x86 compatible
    Product: WinNt, suite: TerminalServer SingleUserTS
    Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055ab20
    Debug session time: Sat Jun 9 02:58:24.578 2007 (GMT+8)
    System Uptime: 0 days 0:11:27.132
    Loading Kernel Symbols
    Loading User Symbols
    Loading unloaded module list
    Unable to load image USBPORT.SYS, Win32 error 0n2
    *** WARNING: Unable to verify timestamp for USBPORT.SYS
    *** ERROR: Module load completed but symbols could not be loaded for USBPORT.SYS
    * Bugcheck Analysis *
    BugCheck FE, {5, 820390e0, 11063038, 81c4ca48}
    ANALYSIS: Kernel with unknown size. Will force reload symbols with known size.
    ANALYSIS: Force reload command: .reload /f ntoskrnl.exe=FFFFFFFF804D7000,214600,41108004
    ***** Kernel symbols are WRONG. Please fix symbols to do analysis.
    *** WARNING: Unable to verify timestamp for usbuhci.sys
    *** ERROR: Module load completed but symbols could not be loaded for usbuhci.sys
    Probably caused by : usbuhci.sys ( usbuhci+305c )
    Followup: MachineOwner
    kd> !analyze -v
    BUGCODE_USB_DRIVER (fe)
    USB Driver bugcheck, first parameter is USB bugcheck code.
    Arguments:
    Arg1: 00000005, USB Bugcheck Code:
    Arg2: 820390e0
    Arg3: 11063038
    Arg4: 81c4ca48
    Debugging Details:
    MODULE_NAME: usbuhci
    FAULTING_MODULE: 804d7000 nt
    DEBUG_FLR_IMAGE_TIMESTAMP: 41107d62
    CUSTOMER_CRASH_COUNT: 5
    DEFAULT_BUCKET_ID: WRONG_SYMBOLS
    BUGCHECK_STR: 0xFE
    LAST_CONTROL_TRANSFER: from f7ff4cc3 to 805339ae
    STACK_TEXT:
    8055074c f7ff4cc3 000000fe 00000005 820390e0 nt+0x5c9ae
    8055076c f8001516 82039028 00008fd0 81bc5000 USBPORT+0xecc3
    805507a8 f892905c 33a6c8f0 820399dc 81c4ca48 USBPORT+0x1b516
    805507cc f8926ded 820399dc 81bc5000 805507fc usbuhci+0x305c
    805507dc f7fee2ba 820399dc 81c4ca48 804e3579 usbuhci+0xded
    805507fc f7fef578 026c6f50 820390e0 81c4c8d0 USBPORT+0x82ba
    80550824 f7ff2ed0 82039028 50457270 804e3579 USBPORT+0x9578
    80550854 f8000fb0 82039028 804e3579 82039028 USBPORT+0xced0
    80550890 f8001128 82039028 00000001 80559580 USBPORT+0x1afb0
    805508ac 804dc179 8203964c 6b755044 00000000 USBPORT+0x1b128
    805508b0 8203964c 6b755044 00000000 820390ec nt+0x5179
    805508b4 6b755044 00000000 820390ec 80559320 0x8203964c
    805508b8 00000000 820390ec 80559320 ffdffc50 0x6b755044
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    usbuhci+305c
    f892905c ?? ???
    SYMBOL_STACK_INDEX: 3
    FOLLOWUP_NAME: MachineOwner
    IMAGE_NAME: usbuhci.sys
    SYMBOL_NAME: usbuhci+305c
    kd> lmvm usbuhci
    start end module name
    f8926000 f892b000 usbuhci T (no symbols)
    Loaded symbol image file: usbuhci.sys
    Image path: usbuhci.sys
    Image name: usbuhci.sys
    Timestamp: Wed Aug 04 14:08:34 2004 (41107D62)
    CheckSum: 00013083
    ImageSize: 00005000
    Translations: 0000.04b0 0000.04e0 0409.04b0 0409.04e0
  2. 2007/06/09
