BSOD when wireless card is enabled w/ DUMP DATA
Discussion in 'Windows XP' started by oliveman6, 2009/10/06.
  1. 2009/10/06
    oliveman6
    oliveman6 Inactive Thread Starter
    Just bought a refurb Compaq Evo n620c w/ a wlan w200 wireless adapter. I had to reinstall Windows XP shortly a few days ago and after I downloaded the new driver from HP Support I always get the BSOD when I enable the wireless adapter. Anyways, here is the dump data.
    Opened log file 'c:debuglog.txt'
    Microsoft (R) Windows Debugger Version 6.11.0001.404 X86
    Loading Dump File [C:\WINDOWS\Minidump\Mini100609-02.dmp]
    Executable search path is: C:\WINDOWS;C:\WINDOWS\system32;C:\WINDOWS\system32\drivers
    Windows XP Kernel Version 2600 (Service Pack 2) UP Free x86 compatible
    Product: WinNt
    Built by: 2600.xpsp_sp2_rtm.040803-2158
    Machine Name:
    Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055ab20
    Debug session time: Tue Oct 6 10:55:02.067 2009 (GMT-4)
    System Uptime: 0 days 0:12:36.649
    Loading Kernel Symbols
    Loading User Symbols
    Loading unloaded module list
    * Bugcheck Analysis *
    BugCheck A, {10102f2, 2, 1, 804e6fa9}
    *** ERROR: Module load completed but symbols could not be loaded for wlcom51b.sys
    Probably caused by : wlcom51b.sys ( wlcom51b+6464 )
    Followup: MachineOwner
    kd> !analyze -v;r;kv;lmtn;.logclose;q
    IRQL_NOT_LESS_OR_EQUAL (a)
    interrupt request level (IRQL) that is too high. This is usually
    caused by drivers using improper addresses.
    If a kernel debugger is available get the stack backtrace.
    Arguments:
    Arg1: 010102f2, memory referenced
    Arg2: 00000002, IRQL
    Arg3: 00000001, bitfield :
    bit 0 : value 0 = read operation, 1 = write operation
    bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
    Arg4: 804e6fa9, address which referenced memory
    Debugging Details:
    WRITE_ADDRESS: 010102f2
    CURRENT_IRQL: 2
    FAULTING_IP:
    nt!KeSetTimerEx+29
    804e6fa9 8901 mov dword ptr [ecx],eax
    CUSTOMER_CRASH_COUNT: 2
    BUGCHECK_STR: 0xA
    TRAP_FRAME: f896bc60 -- (.trap 0xfffffffff896bc60)
    ErrCode = 00000002
    eax=500018dd ebx=00000000 ecx=010102f2 edx=00000000 esi=81b52038 edi=81b52038
    eip=804e6fa9 esp=f896bcd4 ebp=f896bce4 iopl=0 nv up ei pl nz na pe nc
    cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010206
    nt!KeSetTimerEx+0x29:
    804e6fa9 8901 mov dword ptr [ecx],eax ds:0023:010102f2=????????
    .trap
    Resetting default scope
    LAST_CONTROL_TRANSFER: from 804e6fa9 to 804e2158
    STACK_TEXT:
    f896bc60 804e6fa9 badb0d00 00000000 00000000 nt!KiTrap0E+0x233
    f896bce4 804dc9b2 50b52038 00000000 00000000 nt!KeSetTimerEx+0x29
    f896bd00 f8357f7f 81b52038 00000000 00000000 nt!KeSetTimer+0x18
    f896bd28 f833f54b 81b52038 00000000 819decc0 NDIS!NdisMSetTimer+0x8b
    f896bd3c ecc5e464 81b52038 00000000 81b4f000 NDIS!NdisSetTimer+0x44
    f896bd74 804e47fe 81a8f480 00000000 823c78b8 wlcom51b+0x6464
    f896bdac 8057dfed 81a8f480 00000000 00000000 nt!ExpWorkerThread+0x100
    f896bddc 804fa477 804e4729 00000000 00000000 nt!PspSystemThreadStartup+0x34
    00000000 00000000 00000000 00000000 00000000 nt!KiThreadStartup+0x16
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    wlcom51b+6464
    ecc5e464 8a5604 mov dl,byte ptr [esi+4]
    SYMBOL_STACK_INDEX: 5
    SYMBOL_NAME: wlcom51b+6464
    FOLLOWUP_NAME: MachineOwner
    MODULE_NAME: wlcom51b
    IMAGE_NAME: wlcom51b.sys
    DEBUG_FLR_IMAGE_TIMESTAMP: 4179125b
    FAILURE_BUCKET_ID: 0xA_wlcom51b+6464
    eax=ffdff13c ebx=00000002 ecx=00000000 edx=40000000 esi=804e6fa9 edi=010102f2
    eip=804e2158 esp=f896bc48 ebp=f896bc60 iopl=0 nv up ei ng nz na pe nc
    cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00000286
    nt!KiTrap0E+0x233:
    804e2158 f7457000000200 test dword ptr [ebp+70h],20000h ss:0010:f896bcd0=00010206
    f896bc60 804e6fa9 badb0d00 00000000 00000000 nt!KiTrap0E+0x233 (FPO: [0,0] TrapFrame @ f896bc60)
    f896bce4 804dc9b2 50b52038 00000000 00000000 nt!KeSetTimerEx+0x29 (FPO: [5,1,4])
    f896bd00 f8357f7f 81b52038 00000000 00000000 nt!KeSetTimer+0x18 (FPO: [4,0,0])
    f896bd28 f833f54b 81b52038 00000000 819decc0 NDIS!NdisMSetTimer+0x8b (FPO: [2,2,0])
    f896bd3c ecc5e464 81b52038 00000000 81b4f000 NDIS!NdisSetTimer+0x44 (FPO: [2,0,4])
    f896bdac 8057dfed 81a8f480 00000000 00000000 nt!ExpWorkerThread+0x100 (FPO: [1,8,0])
    f896bddc 804fa477 804e4729 00000000 00000000 nt!PspSystemThreadStartup+0x34 (FPO: [Non-Fpo])
    start end module name
    804d7000 806eb780 nt ntoskrnl.exe Wed Aug 04 02:19:48 2004 (41108004)
    806ec000 806ffd80 hal halacpi.dll Wed Aug 04 01:59:04 2004 (41107B28)
    bf800000 bf9c0380 win32k win32k.sys Wed Aug 04 02:17:30 2004 (41107F7A)
    bf9c1000 bf9d2580 dxg dxg.sys Wed Aug 04 02:00:51 2004 (41107B93)
    bf9d3000 bfa09000 ati2dvag ati2dvag.dll Sat May 15 21:29:32 2004 (40A6C3FC)
    bfa09000 bfa41000 ati2cqag ati2cqag.dll Sat May 15 21:14:38 2004 (40A6C07E)
    bfa41000 bfb15960 ati3d1ag ati3d1ag.dll Sat May 15 21:20:57 2004 (40A6C1F9)
    ecc58000 ecc84c00 wlcom51b wlcom51b.sys Fri Oct 22 09:59:55 2004 (4179125B)
    ecc85000 eccaef00 kmixer kmixer.sys Wed Aug 04 02:07:46 2004 (41107D32)
    ecedf000 ecf1f380 HTTP HTTP.sys Wed Aug 04 02:00:09 2004 (41107B69)
    ed330000 ed382180 srv srv.sys Wed Aug 04 02:14:44 2004 (41107ED4)
    ed3ab000 ed3d7400 mrxdav mrxdav.sys Wed Aug 04 02:00:49 2004 (41107B91)
    ed51d000 ed531400 wdmaud wdmaud.sys Wed Aug 04 02:15:03 2004 (41107EE7)
    ed7ba000 ed7c8d80 sysaudio sysaudio.sys Wed Aug 04 02:15:54 2004 (41107F1A)
    ed87a000 ed88f580 irda irda.sys Wed Aug 04 02:00:50 2004 (41107B92)
    ed99c000 ed99f280 ndisuio ndisuio.sys Wed Aug 04 02:03:10 2004 (41107C1E)
    edac0000 edad7480 dump_atapi dump_atapi.sys Wed Aug 04 01:59:41 2004 (41107B4D)
    edad8000 edafb000 Fastfat Fastfat.SYS Wed Aug 04 02:14:15 2004 (41107EB7)
    edafb000 edb4c000 avgldx86 avgldx86.sys unavailable (00000000)
    edbde000 edc4c380 mrxsmb mrxsmb.sys Wed Aug 04 02:15:14 2004 (41107EF2)
    edc4d000 edc78180 rdbss rdbss.sys Wed Aug 04 02:20:05 2004 (41108015)
    edc79000 edc9ad00 afd afd.sys Wed Aug 04 02:14:13 2004 (41107EB5)
    edcb3000 edcb5900 Dxapi Dxapi.sys Fri Aug 17 16:53:19 2001 (3B7D843F)
    edcc3000 edce3f00 ipnat ipnat.sys Wed Aug 04 02:04:48 2004 (41107C80)
    edd61000 eddcc000 vsdatant vsdatant.sys Mon Feb 16 01:49:51 2009 (49990C8F)
    eddcc000 eddf3c00 netbt netbt.sys Wed Aug 04 02:14:36 2004 (41107ECC)
    eddf4000 ede0d000 avgtdix avgtdix.sys unavailable (00000000)
    ede0d000 ede64a80 tcpip tcpip.sys Wed Aug 04 02:14:39 2004 (41107ECF)
    ede65000 ede77400 ipsec ipsec.sys Wed Aug 04 02:14:27 2004 (41107EC3)
    f7fc0000 f7ff3200 update update.sys Wed Aug 04 01:58:32 2004 (41107B08)
    f7ff4000 f8024100 rdpdr rdpdr.sys Wed Aug 04 02:01:10 2004 (41107BA6)
    f805e000 f806ee00 psched psched.sys Wed Aug 04 02:04:16 2004 (41107C60)
    f806f000 f8085680 ndiswan ndiswan.sys Wed Aug 04 02:14:30 2004 (41107EC6)
    f8086000 f809d940 aeaudio aeaudio.sys Thu Oct 23 14:17:07 2003 (3F981B23)
    f809e000 f80c1980 portcls portcls.sys Wed Aug 04 02:15:47 2004 (41107F13)
    f80c2000 f8152840 smwdm smwdm.sys Wed Dec 17 15:29:46 2003 (3FE0BCBA)
    f8153000 f8175680 ks ks.sys Wed Aug 04 02:15:20 2004 (41107EF8)
    f818d000 f81a0900 parport parport.sys Wed Aug 04 01:59:04 2004 (41107B28)
    f81a1000 f81c9b00 b57xp32 b57xp32.sys Fri Jan 17 17:22:06 2003 (3E28820E)
    f81ca000 f81ece80 USBPORT USBPORT.SYS Wed Aug 04 02:08:34 2004 (41107D62)
    f81ed000 f8200780 VIDEOPRT VIDEOPRT.SYS Wed Aug 04 02:07:04 2004 (41107D08)
    f8201000 f82c8000 ati2mtag ati2mtag.sys Sat May 15 21:29:11 2004 (40A6C3E7)
    f82dc000 f82de280 rasacd rasacd.sys Fri Aug 17 16:55:39 2001 (3B7D84CB)
    f8310000 f832a580 Mup Mup.sys Wed Aug 04 02:15:20 2004 (41107EF8)
    f832b000 f833f000 srescan srescan.sys Sat Oct 04 14:27:25 2008 (48E7B58D)
    f833f000 f836ba80 NDIS NDIS.sys Wed Aug 04 02:14:27 2004 (41107EC3)
    f836c000 f83f8480 Ntfs Ntfs.sys Wed Aug 04 02:15:06 2004 (41107EEA)
    f83f9000 f840f780 KSecDD KSecDD.sys Wed Aug 04 01:59:45 2004 (41107B51)
    f8410000 f8421f00 sr sr.sys Wed Aug 04 02:06:22 2004 (41107CDE)
    f8422000 f8440780 fltMgr fltMgr.sys Wed Aug 04 02:01:17 2004 (41107BAD)
    f8441000 f8458800 SCSIPORT SCSIPORT.SYS Wed Aug 04 01:59:39 2004 (41107B4B)
    f8459000 f8470480 atapi atapi.sys Wed Aug 04 01:59:41 2004 (41107B4D)
    f8471000 f8496700 dmio dmio.sys Wed Aug 04 02:07:13 2004 (41107D11)
    f8497000 f84b5880 ftdisk ftdisk.sys Fri Aug 17 16:52:41 2001 (3B7D8419)
    f84b6000 f84d3480 pcmcia pcmcia.sys Wed Aug 04 02:07:45 2004 (41107D31)
    f84d4000 f84e4a80 pci pci.sys Wed Aug 04 02:07:45 2004 (41107D31)
    f84e5000 f8512d80 ACPI ACPI.sys Wed Aug 04 02:07:35 2004 (41107D27)
    f8534000 f853cc00 isapnp isapnp.sys Fri Aug 17 16:58:01 2001 (3B7D8559)
    f8544000 f854e500 MountMgr MountMgr.sys Wed Aug 04 01:58:29 2004 (41107B05)
    f8554000 f8560c80 VolSnap VolSnap.sys Wed Aug 04 02:00:14 2004 (41107B6E)
    f8564000 f856ce00 disk disk.sys Wed Aug 04 01:59:53 2004 (41107B59)
    f8574000 f8580200 CLASSPNP CLASSPNP.SYS Wed Aug 04 02:14:26 2004 (41107EC2)
    f8584000 f858e580 agp440 agp440.sys Wed Aug 04 02:07:40 2004 (41107D2C)
    f8624000 f862cd00 intelppm intelppm.sys Wed Aug 04 01:59:19 2004 (41107B37)
    f8634000 f8643d80 serial serial.sys Wed Aug 04 02:15:51 2004 (41107F17)
    f8644000 f8650e00 i8042prt i8042prt.sys Wed Aug 04 02:14:36 2004 (41107ECC)
    f8654000 f8660180 cdrom cdrom.sys Wed Aug 04 01:59:52 2004 (41107B58)
    f8664000 f8672080 redbook redbook.sys Wed Aug 04 01:59:34 2004 (41107B46)
    f8674000 f8682b80 drmk drmk.sys Wed Aug 04 02:07:54 2004 (41107D3A)
    f8684000 f8690880 rasl2tp rasl2tp.sys Wed Aug 04 02:14:21 2004 (41107EBD)
    f8694000 f869e200 raspppoe raspppoe.sys Wed Aug 04 02:05:06 2004 (41107C92)
    f86a4000 f86afd00 raspptp raspptp.sys Wed Aug 04 02:14:26 2004 (41107EC2)
    f86b4000 f86bc900 msgpc msgpc.sys Wed Aug 04 02:04:11 2004 (41107C5B)
    f86c4000 f86cdf00 termdd termdd.sys Wed Aug 04 01:58:52 2004 (41107B1C)
    f86d4000 f86dd480 NDProxy NDProxy.SYS Fri Aug 17 16:55:30 2001 (3B7D84C2)
    f8704000 f8712100 usbhub usbhub.sys Wed Aug 04 02:08:40 2004 (41107D68)
    f8734000 f873c700 wanarp wanarp.sys Wed Aug 04 02:04:57 2004 (41107C89)
    f8744000 f874c700 netbios netbios.sys Wed Aug 04 02:03:19 2004 (41107C27)
    f8764000 f876c880 Fips Fips.SYS Fri Aug 17 21:31:49 2001 (3B7DC585)
    f87b4000 f87ba200 PCIIDEX PCIIDEX.SYS Wed Aug 04 01:59:40 2004 (41107B4C)
    f87bc000 f87c0900 PartMgr PartMgr.sys Fri Aug 17 21:32:23 2001 (3B7DC5A7)
    f87c4000 f87cb1c0 cercsr6 cercsr6.sys Wed Dec 08 18:31:10 2004 (41B78EBE)
    f87ec000 f87f1000 usbuhci usbuhci.sys Wed Aug 04 02:08:34 2004 (41107D62)
    f87f4000 f87fa800 usbehci usbehci.sys Wed Aug 04 02:08:34 2004 (41107D62)
    f87fc000 f8803000 fdc fdc.sys unavailable (00000000)
    f8804000 f880a000 kbdclass kbdclass.sys Wed Aug 04 01:58:32 2004 (41107B08)
    f880c000 f8811a00 mouclass mouclass.sys Wed Aug 04 01:58:32 2004 (41107B08)
    f8814000 f8818c80 rasirda rasirda.sys Fri Aug 17 16:51:29 2001 (3B7D83D1)
    f881c000 f8820880 TDI TDI.SYS Wed Aug 04 02:07:47 2004 (41107D33)
    f882c000 f8830580 ptilink ptilink.sys Fri Aug 17 16:49:53 2001 (3B7D8371)
    f8834000 f8838080 raspti raspti.sys Fri Aug 17 16:55:32 2001 (3B7D84C4)
    f884c000 f8851200 vga vga.sys Wed Aug 04 02:07:06 2004 (41107D0A)
    f8854000 f8858a80 Msfs Msfs.SYS Wed Aug 04 02:00:37 2004 (41107B85)
    f885c000 f8863880 Npfs Npfs.SYS Wed Aug 04 02:00:38 2004 (41107B86)
    f8874000 f887a780 USBSTOR USBSTOR.SYS Wed Aug 04 02:08:44 2004 (41107D6C)
    f8884000 f8889280 avgmfx86 avgmfx86.sys Wed Jul 01 16:37:21 2009 (4A4BC901)
    f88b4000 f88b8500 watchdog watchdog.sys Wed Aug 04 02:07:32 2004 (41107D24)
    f8944000 f8947000 BOOTVID BOOTVID.dll Fri Aug 17 16:49:09 2001 (3B7D8345)
    f8948000 f894a480 compbatt compbatt.sys Fri Aug 17 16:57:58 2001 (3B7D8556)
    f894c000 f894f700 BATTC BATTC.SYS Fri Aug 17 16:57:52 2001 (3B7D8550)
    f89d8000 f89dbc80 serenum serenum.sys Wed Aug 04 01:59:06 2004 (41107B2A)
    f89e0000 f89e3700 CmBatt CmBatt.sys Wed Aug 04 02:07:39 2004 (41107D2B)
    f89e4000 f89e6280 wmiacpi wmiacpi.sys Wed Aug 04 02:07:39 2004 (41107D2B)
    f89ec000 f89ee580 ndistapi ndistapi.sys Fri Aug 17 16:55:29 2001 (3B7D84C1)
    f8a08000 f8a0bc80 mssmbios mssmbios.sys Wed Aug 04 02:07:47 2004 (41107D33)
    f8a34000 f8a35b80 kdcom kdcom.dll Fri Aug 17 16:49:10 2001 (3B7D8346)
    f8a36000 f8a37100 WMILIB WMILIB.SYS Fri Aug 17 17:07:23 2001 (3B7D878B)
    f8a38000 f8a39580 intelide intelide.sys Wed Aug 04 01:59:40 2004 (41107B4C)
    f8a3a000 f8a3c000 dmload dmload.sys unavailable (00000000)
    f8a48000 f8a49100 swenum swenum.sys Wed Aug 04 01:58:41 2004 (41107B11)
    f8a4a000 f8a4b280 USBD USBD.SYS Fri Aug 17 17:02:58 2001 (3B7D8682)
    f8a4c000 f8a4e000 Fs_Rec Fs_Rec.SYS unavailable (00000000)
    f8a4e000 f8a4f080 Beep Beep.SYS Fri Aug 17 16:47:33 2001 (3B7D82E5)
    f8a50000 f8a51080 mnmdd mnmdd.SYS Fri Aug 17 16:57:28 2001 (3B7D8538)
    f8a52000 f8a53080 RDPCDD RDPCDD.sys Fri Aug 17 16:46:56 2001 (3B7D82C0)
    f8aae000 f8aaf100 dump_WMILIB dump_WMILIB.SYS Fri Aug 17 17:07:23 2001 (3B7D878B)
    f8ac4000 f8ac5a80 ParVdm ParVdm.SYS Fri Aug 17 16:49:49 2001 (3B7D836D)
    f8afc000 f8afcd00 PCIIde PCIIde.sys Fri Aug 17 16:51:49 2001 (3B7D83E5)
    f8bd1000 f8bd1d00 dxgthk dxgthk.sys Fri Aug 17 16:53:12 2001 (3B7D8438)
    f8c0d000 f8c0dc00 audstub audstub.sys Fri Aug 17 16:59:40 2001 (3B7D85BC)
    f8c84000 f8c85000 Null Null.SYS unavailable (00000000)
    Unloaded modules:
    ecd4d000 ecd77000 kmixer.sys
    Checksum: 00000000
    ed4d0000 ed4fa000 kmixer.sys
    Checksum: 00000000
    f8b65000 f8b66000 drmkaud.sys
    Checksum: 00000000
    ed930000 ed93d000 DMusic.sys
    Checksum: 00000000
    ed960000 ed96e000 swmidi.sys
    Checksum: 00000000
    ed4fa000 ed51d000 aec.sys
    Checksum: 00000000
    f8a86000 f8a88000 splitter.sys
    Checksum: 00000000
    f8754000 f875f000 imapi.sys
    Checksum: 00000000
    f8844000 f8849000 Cdaudio.SYS
    Checksum: 00000000
    f82e0000 f82e3000 Sfloppy.SYS
    Checksum: 00000000
    f883c000 f8841000 Flpydisk.SYS
    Checksum: 00000000
    Closing open log file c:debuglog.txt
  2. 2009/10/06
    Since your driver is a 2004 version
    try & see if there's a newer (or older) version that works without crashing.
    You'll probably better off with an add-in WiFi card (PCMCIA type). Seems loads of problems with this Compaq driver.
    oliveman6
    Thanks for the reply, any idea where I can download this type of file? I have tried the older version of the driver with the same result.
  5. 2009/10/06
    I think you are SOL.
    I can only find the 2004 file on the Compaq site.
    oliveman6
    Can you suggest an inexpensive PCMCIA wireless card for me? My home router is a Belkin if that matters
  7. 2009/10/08
    Lot's of stuff can be found on eBay. If you're happy with your Belkin, you could get a Belkin Wireless Notebook Network Card. Make sure you get at least a "G" (802.11g) card. If your router is "N" capable, you might also go for an "N" card.
