Resolved BSOD Unknown_Module
Discussion in 'Windows 7' started by Lolicore Flandr, 2011/08/26.
  1. 2011/08/26
    Lolicore Flandr
    Lolicore Flandr Inactive Thread Starter
    Hi WindowsBBS,as you can see im a new user and im glad to be here.
    Now on to the problem.Today i was woken up by mom and saying 'The PC is broken!' i took a look at it and it consist of the same problem - monitor shuting itself down but the PC is still running,though thats a BSOD,the monitor just aint showin it.I got a handy program BlueScreenView to analyze whats the problem but to my suprise this report came up
    Dump File : 082611-13984-01.dmp
    Crash Time : 26.8.2011 г. 08:27:15 ч.
    Bug Check String :
    Bug Check Code : 0x00000116
    Parameter 1 : 0x87f98510
    Parameter 2 : 0x92229152
    Parameter 3 : 0xc000009a
    Parameter 4 : 0x00000004
    Caused By Driver : C_62206e65
    Caused By Address : Unknown_Module_62206e65+25d916ab
    File Description :
    Product Name :
    Company :
    File Version :
    Processor : 32-bit
    Crash Address : Unknown_Module_62206e65+20d26fd7
    Stack Address 1 : Unknown_Module_62206e65+2f314c76
    Stack Address 2 : Unknown_Module_62206e65+2f30edaf
    Stack Address 3 : Unknown_Module_62206e65+2f315b66
    Computer Name :
    Full Path : C:\Windows\Minidump\082611-13984-01.dmp
    Processors Count : 2
    Major Version : 15
    Minor Version : 7600
    Dump File Size : 131*072
    also with that here are the computer's specs
    Windows 7 Ultimate
    ASRock N68-S (NVIDIA GeForce 7025/nForce 630a Chipset)
    AMD Athlon 64 X2 Dual Core 4200+ @ 2.21GHz
    2048MB RAM DDR2 1066
    NVIDIA GeForce 330GT i think
    Thank you for your time.
  2. 2011/08/26
    Welcome to WindowBBS :)
    Your Bug Check Code is indicative of a graphics driver error - I suggest you update the driver as a first step .....
    http://www.nvidia.com/Download/index.aspx?lang=en-us
    Use Option 2 - Automatically find drivers for my NVIDIA products.
    Lolicore Flandr
    I've updated the graphics drivers to the latest
    The problem appeared again.This time with more info.
    Dump File : 082611-14718-01.dmp
    Crash Time : 26.8.2011 г. 10:52:53 ч.
    Bug Check String :
    Parameter 1 : 0x84f9c510
    Parameter 2 : 0x9141e152
    Caused By Driver : nvlddmkm.sys
    Caused By Address : nvlddmkm.sys+614152
    File Description : NVIDIA Windows Kernel Mode Driver, Version 280.26
    Product Name : NVIDIA Windows Kernel Mode Driver, Version 280.26
    Company : NVIDIA Corporation
    File Version : 8.17.12.8026
    Processor : 32-bit
    Crash Address : ntkrnlpa.exe+dce3c
    Stack Address 1 : dxgkrnl.sys+8cadb
    Stack Address 2 : dxgkrnl.sys+86c14
    Stack Address 3 : dxgkrnl.sys+8d9cb
    Computer Name :
    Full Path : C:\Windows\Minidump\082611-14718-01.dmp
    Major Version : 15
    Dump File Size : 248*144
    For now going to take it to a expert to check & diagnost.Must be some fault from the GPU,the drivers should be fine.
    Thank you for your reply.
  5. 2011/08/26
    If you'd run the dump through our tool, we get more information which could help.
    Follow these instructions to post a Dump Data Log.
  6. 2011/08/28
    Lolicore Flandr
    Wont be needed i found the cause.I tested the GPU on my computer and it overheats (reached 101 degrees Celcius) and just 80 while just running only on desktop.
    Thanks for your help! ;3
  7. 2011/08/28
    You're welcome :)
