Browser Problem
Discussion in 'Internet Explorer & Microsoft Edge' started by bluenose12, 2003/10/19.
  1. 2003/10/19
    bluenose12
    bluenose12 Inactive Thread Starter
    When I start Internet Explorer 6 and go to my favourites and click the links...sometimes I get that annoying white screen telling me to try the refresh button.Sometimes I have to exit IE and start it again and click the link again before i get access to the sites.
    Any Ideas??:(
  2. 2003/10/19
    markp62
    markp62 Geek Member Alumni
    Try running the Internet Explorer Repair Tool.
    Welshjim
    Welshjim Inactive
    bluenose12--If this happens only sometimes, it could be your ISP's server being temporarily down or slow. Not much you can do about that. (except complain!! :) )
    But if this happens usually and over a period of days, does this happen only with links from Favourites, or other links such as those from an internet page?
    If the latter, more general situation, you might have a look here
    http://support.microsoft.com/default.aspx?scid=kb;en-us;281679
  5. 2003/10/19
    bluenose12
    I've tried setting my Internet Exploere settings to the default.
    Will this make any difference?
    BTW Where do I find the Internet Explorer Repair Tool?
  6. 2003/10/20
    markp62
    With 9x and ME, to Control Panel\Add Remove Programs, double click the IE entry, a window will pop up, choose the Repair Option. Reboot when prompted.
    With XP, there are a couple ways to do it.
    One way to repair Internet Explorer is to have sfc check the system files by clicking on the Start Menu, then Run, and type in:
    sfc /scannow
    Or
    Go to the Run dialog box in either 2000 or XP and type or copy and paste this line of code into the entry field - rundll32 setupwbv.dll,IE6Maintenance "C:\Program Files\Internet Explorer\Setup\SETUP.EXE" /g "C:\WINDOWS\IE Uninstall Log.Txt " . If you are running 2000 and run IE5 then simply replace the IE6 with IE5.
  7. 2003/10/20
    bluenose12
    Thanks Mark...I will try that.:)
  8. 2003/10/20
    bluenose12
    I ran that sfc file check thingy(very technical eh?:D ).
    Is it my imagination?...My Internet sites seem to open faster now.:)
    The sfc check asked for my Win XP disk and it replaced dll files.
  9. 2003/10/20
    markp62
    Good to hear. Those files replaced were corrupt.
