Resolved Browser Display Problem.
Discussion in 'Internet Explorer & Microsoft Edge' started by BreezyCricket, 2011/06/28.
  1. 2011/06/28
    BreezyCricket Lifetime Subscription
    BreezyCricket Well-Known Member Thread Starter
    I am using Windows XP Professional.
    When I start Internet Explorer 8 it loads www.sympatico.ca as my home page but neither the text nor the images load. All I get is a blue screen, not a BSOD but a screen starting at the top as dark blue and gradually lightening towards the bottom. This can best be seen by loading the page using a screen resolution greater than 1024 x 768 which will show a blue strip on either side of the screen content and this is what covers my entire screen.
    However, if I then refresh the screen it corrects itself.
    If I start the Google Chrome browser it loads the same page without any problems.
    I have done all the usual troubleshooting, ie virus, spyware checks and I have cleared the cache and everything else I could think of to clear but nothing has helped.
    I certainly would appreciate any suggestions as to what may be causing the problem.
    Many Thanks.
  2. 2011/06/28
    Tools->Options->General tab->Browsing History "settings" button->Select the first option-> Everytime I visit a page
    Thank You for the reply.
    I had already tried that and it made no difference.
  5. 2011/06/28
  6. 2011/06/29
    Well, I would first start with deleting the Temporary Internet files before trying anything else.
  7. 2011/06/29
    Had already deleted temporary internet files and that did not help.
    I finally re-installed Internet Explorer 8 and this did not help but this morning the problem disappeared so I don't know what caused it but at least it has gone.
    Thanks all for the help.
