booting up problem
Discussion in 'PC Hardware' started by Jerry72, 2003/04/08.
  1. 2003/04/08
    Jerry72
    Jerry72 Inactive Thread Starter
    On starting I get this message onthe screen :CHECKING NV RAM..
    I replaaced the memory with a new 256 MB RAM. Also replaced the CMOS battery.No results.I reinstallled the same module in another bank,then I have the 3 beeps(bad memory). Now,I installled the same memory module in another computer,and it worked fine.What did I do wrong?
    Jerry
  2. 2003/04/08
    reboot
    reboot Inactive
    Why did you change RAM?
    The message "Checking NVRAM" is standard.
    If the computer stopped working or something, please post exactly where it quit, and a bit about your hardware.
    Jerry72
    boot up propblem
    I know it is standard,but it halted for more than 15 min.I changed the Ram because one technician on the Web told me to do so.I alo replaced the battery.This is my screen:
    Check system health OK
    Checking NVRAM..
    CPU ID:068A American Mega Trends 0001
    Intel Celeron(tm)800 MKHZ
    Ami Bios(c)1999
    6VMML F3
    GAVMM002-F
    AND IT STOPPED.
    Jerry
  5. 2003/04/09
    mindbug
    mindbug Inactive
    hi, jerry
    Have you checked the site of your motherboard for known bugs?
    maybe it can be resolved with a bios update
    when occured this problem and under wich kind of conditions?
    greetz, mindbug
  6. 2003/04/09
    reboot
    reboot Inactive
    Looks like it's making it almost all the way through POST, but maybe hanging right at the end, or when initializing video or hard drives.
    Have you been into the BIOS setup?
    Are IDE devices all detected properly?
  7. 2003/04/09
    Jerry72
    bootup problem
    The problem occured when I start the computer.I can even get to the BIOS.It halted on : CHECKING NVRAM...No devices were detected.No Ram detected.How can I use a BIOS update if my computer does not work?
    Jerry
  8. 2003/04/09
    reboot
    reboot Inactive
    Dig through the motherboard manual, and reset the CMOS.
    See if you can get past the error then.
