Boot up & Reboot (long delay) using USB port to HP Printer (see details)
Discussion in 'Windows XP' started by piperman, 2006/06/25.
  1. 2006/06/25
    piperman
    piperman Inactive Thread Starter
    I have windows xp pro with SP2. I have a HP photosmart 2610v all in one printer,fax,scanner,copier. I have traced out by unhooking all hardware and my reboot problem goes away. I found that everything works fine until I connect the 2610 printer to the USB port and the problem re-occurs. When this problem happens I notice that the curser in the upper left hand part of the screen will flash probably up to 5 min and it will boot. I have actually reached down and unplugged the USB while in the reboot and it goes ahead and boots fine. I have unloaded and reloaded all drivers from the updates page of hp home URL for this unit. This did not help. Since I have found disconnecting while in the reboot and replacing the plug after windows reboots i can reboot normally. I guess if I can't resolve this issue or no one has an answer for a fix, I can continue to unplug the USB plug from the Port while in the reboot.
    Piperman
  2. 2006/06/25
    piperman - Welcome to the Board :)
    I asume you wish you post this thread so have moved it to the XP forum.
