Boot up problems..Computer boots in a loop
Discussion in 'Windows XP' started by eafin, 2004/07/08.
  1. 2004/07/08
    eafin
    eafin Inactive Thread Starter
    OS XP..While trying to add a new 250 gig hard drive, I had problems..Thought things were fine, but when I went to reboot couldnt. Tried to reload XP over top of the old and havent been able to correct the problem. On my old computer trying to rectify problem. Please advise.
    Thanks in advance..
    Eric
  2. 2004/07/08
    Can you force it into a safe-mode startup? If so, set it to not autorestart after a crash so you will get a BSOD that contains details about the error.
    Right-click My Computer then left-click Properties~Advanced~Startup & Recovery Settings then uncheck the box for Automatically Restarting after a System Failure.
    eafin
    Would like to, but...
    I cant even get in to do that...it just goes so far...get a black and white screen..No matter what I chose for an option.. "Last good configuration etc..it just keeps coming back to the same black and white screen...
  5. 2004/07/09
    Dang - that would certainly have been the simplest option. Ah well.
    Take a look Here for details about starting your PC and getting to the recovery console. Once there, type in chkdsk /r and ENTER. If it asks you any questions, answer so that it will run the scandisk for you. That may fix things.
    If not, I think there is a way from the same recovery console to change the setting to force the PC to give a BSOD rather than this endless boot cycle but I don't know what it is. Several others on here do know and hopefully by the time you post back with the details on chkdsk helping or not, they can tell you how. I'd also like to know because it would be very useful for this type of problem and you are not the first to run into it.
