Boot up of XP Pro goes straight to CHKDSK and hangs
Discussion in 'Windows XP' started by john wolfenden, 2006/08/01.
  1. 2006/08/01
    john wolfenden
    john wolfenden Inactive Thread Starter
    Help please - I'm a novice!
    I switch on Dell Dimension running XP Pro and the boot-up goes almost directly to CHKDSK - which starts running.
    It is impossible to Escape or Cntl+Alt+Delete and the utility runs until completion, at which point it freezes.
    The only escape is to switch the machine off.
    Restarting only starts the whole process again.
    What can I do?
    Is this CHKDSK facility authentic or something nasty?
    Many thanks to all
    John W
  2. 2006/08/01
    John W - Welcome to the Board :)
    CHKDSK aka Check Disk is a legitimate Windows process which will run at boot if Windows senses a problem with your hard drive - or on demand by the user at other times.
    The fact that it runs each time you boot and then freezes suggests a potential problem with your hard drive.
    As you have a Dell I guess you have a full copy of XP on the Dell CD rather than a Recovery CD. If this is the case you should boot from the CD to the Recovery Console and run chkdsk from there using the r switch - chkdsk /r
    If you know the make of your hard drive download the disk diagnostic software from the manufacturer's web site and run it.
    MBoogie
    MBoogie Inactive
    found something...
    Hi John
    I'm fighting with the same problem on a colleagues pc... This might help. I wasn't able to test it yet but I'm happy if you would let me know when it worked. You'll need the console PeteC mentioned or a indipendently running OS on a CD like Ubuntu (never used, not sure if you can really access your harddisk)
    http://www.annoyances.org/exec/forum/winxp/1026764766
    Greetings
    M
  5. 2006/08/17
    MBoogie
    MBoogie Inactive
    Hi it's me again. I tried the Ubuntu LiveCD because I couldn't access the console (my friend lost his administration password...). It's pretty cool you get a complete desktop with everything. The only problem was that you couldn't access any NTFS drives... The driver you need is not automatically loaded and my Linux knowledge is zero :-S
    Therefore ultima ratio: format C: *evil grin* I always wanted to do that once in my life... *even more evil grin*
    I hope you're more lucky...
    M
