Resolved Boot Problem
Discussion in 'Windows 7' started by joe645, 2016/04/22.
  1. 2016/04/22
    joe645
    joe645 Well-Known Member Thread Starter
    For some unknown reason my computer wont boot normally. The boot sequence seems to have changed After the bios loads, I get a message that the CPU couldn't find my OS looking on the first device in the menu. I have to reboot and go into the bios and manually find the correct HD which is listed second in the boot menu. I would think it should be in the first position.
  2. 2016/04/22
    rikki
    rikki Well-Known Member
    Different things can cause this. It would be helpful to know more about your system. Probably a boot file or something on your hard drive has become corrupted. Do you have a multi-boot system? The main hard drive is not always the first item listed in the BIOS. It may check for other temporary boot drives first, like a DVD.
    Disconnect ALL peripherals (USB drives) and see if that helps. Neil.
  5. 2016/04/26
    joe645
    This problem has been corrected - so thread can close
  6. 2016/04/26
