Blue screen: IRQ_NOT_LESS_OR_EQUAL
Discussion in 'Windows XP' started by oiler9, 2005/11/19.
  1. 2005/11/19
    oiler9
    oiler9 Inactive Thread Starter
    I have a Dell Dimension and it runs Windows XP. Everytime I try to shut down I get a blue screen with an error message that says IRW_NOT_LESS_OR_EQUAL and a stop:0x0000000A(0x00000304,0x00000002,0x00000002,0x806FFA16). I have tried using rollback, uninstalling recently installed programs and nothing works. Does anyone have any idea what I can do to correct this problem?? Any suggestions would be greatly appreciated. Thanks
  2. 2005/11/19
    oiler9 - Welcome to the Board :)
    Stop 0x0000000A or IRQL_NOT_LESS_OR_EQUAL messages are generally due to faulty or incompatible hardware or software see here and Troubleshooting a Stop 0x0000000A error in Windows XP
    Generally the blue screen references a file or driver which is causing the problem - do you see anything like that?
    Take a look in Event Viewer (right click My Computer icon > Manage > Event Viewer) and look in System and Application for error messages flagged with a white cross on a red ground. Double click on the Error message to open and on the icon below the up/down arrows to copy to clipboard and paste here if relevant.
    oiler9
    PeteC,
    There are quite a few errors in the system and also the application. Is there any I should be looking for in particular??? Event Type: Error
    Event Source: Service Control Manager
    Event Category: None
    Event ID: 7000
    Date: 11/20/2005
    Time: 9:40:38 PM
    User: N/A
    Computer: ADAM
    Description:
    The mrtRate service failed to start due to the following error:
    The system cannot find the file specified.
    For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
    Event Type: Error
    Event Source: Tcpip
    Event ID: 4199
    Date: 11/20/2005
    Time: 10:11:44 AM
    User: N/A
    Computer: ADAM
    Description:
    The system detected an address conflict for IP address 192.168.0.102 with the system having network hardware address 00:11:95:4A:E3:46. Network operations on this system may be disrupted as a result.
    Data:
    0000: 00 00 00 00 03 00 50 00 ......P.
    0008: 00 00 00 00 67 10 00 c0 ....g..À
    0010: 00 00 00 00 00 00 00 00 ........
    0018: 00 00 00 00 00 00 00 00 ........
    0020: 00 00 00 00 00 00 00 00 ........
    Event Type: Error
    Event Source: Application Hang
    Event Category: (101)
    Event ID: 1002
    Date: 11/18/2005
    Time: 11:55:52 AM
    User: N/A
    Computer: ADAM
    Description:
    Hanging application Aolunins_us.exe, version 1.0.0.0, hang module hungapp, version 0.0.0.0, hang address 0x00000000.
    Data:
    0000: 41 70 70 6c 69 63 61 74 Applicat
    0008: 69 6f 6e 20 48 61 6e 67 ion Hang
    0010: 20 20 41 6f 6c 75 6e 69 Aoluni
    0018: 6e 73 5f 75 73 2e 65 78 ns_us.ex
    0020: 65 20 31 2e 30 2e 30 2e e 1.0.0.
    0028: 30 20 69 6e 20 68 75 6e 0 in hun
    0030: 67 61 70 70 20 30 2e 30 gapp 0.0
    0038: 2e 30 2e 30 20 61 74 20 .0.0 at
    0040: 6f 66 66 73 65 74 20 30 offset 0
    0048: 30 30 30 30 30 30 30 0000000
    Event Type: Error
    Event Source: Application Error
    Event ID: 1000
    Date: 11/18/2005
    Time: 11:50:59 AM
    User: N/A
    Computer: ADAM
    Description:
    Faulting application aim.exe, version 5.9.3690.0, faulting module unknown, version 0.0.0.0, fault address 0x1221254f.
    Data:
    0008: 69 6f 6e 20 46 61 69 6c ion Fail
    0010: 75 72 65 20 20 61 69 6d ure aim
    0018: 2e 65 78 65 20 35 2e 39 .exe 5.9
    0020: 2e 33 36 39 30 2e 30 20 .3690.0
    0028: 69 6e 20 75 6e 6b 6e 6f in unkno
    0030: 77 6e 20 30 2e 30 2e 30 wn 0.0.0
    0038: 2e 30 20 61 74 20 6f 66 .0 at of
    0040: 66 73 65 74 20 31 32 32 fset 122
    0048: 31 32 35 34 66 0d 0a 1254f..
    These are the 2 most recent in the system and the application folders. There are more in both folder. Let me know if there are any in particular that i should be looking for. Appreciate all your help.
  5. 2005/11/19
    oiler9
    Here are a few different errors that might be more important:
    Event Type: Error
    Event Source: crypt32
    Event ID: 11
    Date: 11/17/2005
    Time: 11:22:47 AM
    User: N/A
    Computer: ADAM
    Description:
    Failed extract of third-party root list from auto update cab at: <http://www.download.windowsupdate.com/msdownload/update/v3/static/trustedr/en/authrootstl.cab> with error: A required certificate is not within its validity period when verifying against the current system clock or the timestamp in the signed file.
    Event Type: Error
    Event Source: TrueVector Service
    Event ID: 5003
    Date: 11/16/2005
    Time: 8:41:28 PM
    User: N/A
    Computer: ADAM
    Description:
    The description for Event ID ( 5003 ) in Source ( TrueVector Service ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: LoadNTDeviceDriver, Access is denied.
    Event Type: Error
    Event Source: Tcpip
    Event ID: 4199
    Date: 11/20/2005
    Time: 10:11:44 AM
    User: N/A
    Computer: ADAM
    Description:
    Data:
    Event Type: Error
    Event Source: Dhcp
    Event ID: 1002
    Date: 11/20/2005
    Time: 8:01:33 AM
    User: N/A
    Computer: ADAM
    Description:
    The IP address lease 192.168.0.104 for the Network Card with network address 000CF1D7E30E has been denied by the DHCP server 68.112.12.20 (The DHCP Server sent a DHCPNACK message).
  6. 2005/11/20
    mrtRate Service is a part of Quicken
    Aolunins_us.exe id the uninstaller for AOL
    aim.exe is AOL Instant Messenger
    TrueVector Service is part of Zone Alarm or eTrust Firewall
    The crypt32 error relates to Cryptographic Services which are an essential part o Windows Update.
    I would not have thought that these would cause a Blue screen, but you do have a few problems with Quicken, AOL and your firewall.
    Was there anything on the blue screen immediately following IRW_NOT_LESS_OR_EQUAL which related to a file of any sort, specifically a .sys file?
