Best way to uninstall a program?
Discussion in 'Windows XP' started by timmins, 2005/09/06.
  1. 2005/09/06
    timmins
    timmins Well-Known Member Thread Starter
    When uninstalling a program, is better to use the program's own uninstaller or the Add/Remove program feature in Windows? Thanks. :)
  2. 2005/09/06
    Christer
    Christer Geek Member Staff
    There should be no difference since Add/Remove uses the uninstaller from the actual application.
    Christer
    Zander
    Zander Geek Member Alumni
    Christer's right. The two are one in the same. Take your pick. ;)
