Battery check.
Discussion in 'Legacy Windows' started by williamdp, 2006/02/09.
  1. 2006/02/09
    williamdp
    williamdp Inactive Thread Starter
    Hi. Folks, Using Windows 98SE is there any command to determine the state of the motherboard battery. Regards, William.
  2. 2006/02/09
    William
    I am not aware of any command in any OS to give that information. Do you have cause to think that your mobo battery is on the way out?
    williamdp
    Hello Petec. I get a full screen of data from American Megatrends stating bad and wrong data. The computer is 6 years old. I get the option to press F2 key to continue to load default. I checked the search option here and it drew me to battery problems. Hope this helps. Regards, William.
  5. 2006/02/09
    Sounds like the battery is on the way out - I suggest you replace it.
  6. 2006/02/09
    williamdp
    PeteC, Many thanks. Regards, William.
