Barebones system and old HD's
Discussion in 'PC Hardware' started by Hill, 2007/05/27.
  1. 2007/05/27
    Hill
    Hill Inactive Thread Starter
    Hi all
    Very excited to FINALLY have order a new computer after 7 years
    Gigabyte Barebones w/ AMD Athlon 64 X2 4200+ (2.2GHz) (Socket AM2)
    GIGABYTE GA-M61VME-S2 Socket AM2 MCP61V DDR2 A&V&L MATX Motherboard
    ATi Radeon X1650XT 256MB PCI Express Video Card
    I thought I had posted a question like this before but I couldn't find it. Maybe it was somewhere else. Anyways, I want to use my old hd's in the new box.
    Do I need to do a complete reinstall or a repair install of XP or neither. I have a system partition "C" so if I have to do a full reinstall I should only have a few things to back up.
    Also, I have a XP SP2 disks from last fall and there has been a bunch of updates since then. Iam on dialup and would hate to have to download those updates. Would I/ do I "slipstream XP" on to some CDs?
    Heath
    Hill,
  2. 2007/05/27
    Heath
    A Repair install is the way to go, see here ....
    How to replace the motherboard on a computer that is running Windows Server 2003, Windows XP, or Windows 2000
    Is that an XP install CD incorporating SP 2 or a standalone SP 2 CD? If the latter you can slipstream that with a vanilla XP CD, if the former you clearly don't need to.
    There have been a lot of updates, patches since SP2 was released and I can't see how you can avoid downloading them - unless someone knows otherwise.
    http://www.windows-help.net/WindowsXP/winxp-sp2-bootcd.html
    Hill
    Thanks Pete C
    Good I think I can probably handle a repair install.
    Yeah, its a standalone SP2 CD from last fall. Iam up to date, but there has been tons of updates since then can I copy those updates or slipstream them? Iam just not sure which. Or do I need to just DL them again.
    Heath
    Hill,
    You can slipstream the SP 2 CD into your XP CD if you wish, but there is probably not a lot to be gained as you have SP 2 to hand.
    Slipstreaming the Updates is less straightforward as you don't have them as executables on your drive and I am fairly sure that not all are downloadable as such anyway.
    I think you will have to bite the bullet and visit Windows Update after the repair install, which may not overwrite all the currently installed updates, but I cannot recall - a long time since I made a repair install :)
    A further thought - if you have a friend on Broadband take the computer over, load the broadband software and connect to Windows Update - speedily :)
  6. 2007/05/28
    Hill
    Well, I guess I'll have to re DL them.
    My friend next door has satelite internet so maybe that is an option.
    One more question. Will all my programs continue to work properly? There all installed on partition D. Guess Iam worried about the file paths.
    oopps...one more question. Will I need to backup the stuff under C:\Documents and Settings\Heath and the other profiles or will the repair install leave those intact?
    Thanks a bunch
    Heath
    Hill,
    #5
  7. 2007/05/28
    They should do, but no guarantees :)
    The repair should not touch those areas, but the sound advice is always backup, backup ..... :)
    Before proceeding please read .....
    How to perform an in-place upgrade (reinstallation) of Windows XP
    and especially ....
    You May Lose Data or Program Settings After Reinstalling, Repairing, or Upgrading Windows XP
  8. 2007/05/28
    Hill
    Thanks Pete C!!
    THE system should be here by the end of the week.
    Heath
    Hill,
    #7
  9. 2007/05/29
    Good luck and enjoy the experience :) If you run into problems you know where we are!
  10. 2007/06/16
    Hill
    Just an update....
    The comp finally came and start working on it lastnight. So, I thought I would post my experience.
    The repair install worked. Took a few tries but I got it. But, it wasn't as straight forward.
    I booted with the cd in. It loads some drivers then will ask if you want to do a repair install press "R" or load windows. At first I typed "r ". It did a few things and asked (sorry but Iam going from memory) to make a selection of what I wanted to repair. The choice was 1. c:/windows>
    I selected one(1) and then it asked for my admin password I hit enter. Then it went back to c:/windows>
    It was a dos screen.
    So, by now Iam freaking. So, I restarted it.
    At that first screen instaed on typing "r" I selected to install windows normally. It did a few more things. It came to a screen asking if I wanted to "repair" or install. I selected repair and it worked perfectly. Copied drivers and all that .
    So, it seemed a little wacky and seemed like there are two different "repairs "!!??
    my experience
    H
    Hill,
    #9
  11. 2007/06/16
    Yes, that has caught a lot of people out and is really far from clear, despite stating 'Repair using Recovery Console' or words to that effect. Most folks don't have a clue as to what the Recovery Console is and what can be done it it :)
    That said the URL I first posted on changing the motherboard is more definitive ....
    Anyway that's water under the bridge now and you will know next time :)
    Hope all continues to go well and thanks for the update.
  12. 2007/06/16
    McTavish
    McTavish Inactive
    Hill
    The maxtor is like 1 1/2 old. 80gig.
    But, I kind of messed up. The new MB has only one IDE plug so I can only plug one HD and a CDrom. So, I think Iam going to set up a RAID config in a couple weeks(I have no idea how! or what I need) then I can use the ide plug for my cdrom and cdrw. Minor set back but, its a tight little board so Iam happy.
    Thats why I need to only read one "How to" article. Too much info always gets lost in my head.
    Heath
  14. 2007/06/16
    visionof
    visionof Inactive
    Don't use the old harddrives for os use
    Only if they are used for storeage
    Newer hard drives are much faster - simple as that
    Why buy a new fast system and hobble it
    Reliability as well is an issue.
    Even if hard drives were not cheap - why bother both from speed , reliabilty amd cost .
  15. 2007/06/16
    Whiskeyman Inactive Alumni
    A 1 1/2 year old PATA harddrive is not old. I have been running 5 year old Western Digital Caviar PATA harddrives on my system with 2MB cache. I just recently added an 80GB WD Caviar PATA harddrive with 8MB cache. I see no difference in performance. S.M.A.R.T. reports all drives are fine. Data Lifeguard reports all drives are fine. Heck I still have PATA drives from 1996 that still function fine.
  16. 2007/06/18
    Hill
    So, 20 minutes after writing that post above, everything came to a screeching halt!!
    I wasn't able to update windows so I followed this article at windows update and it royally ******* my comp!!
    http://support.microsoft.com/kb/919749/en-us
    Now, I know I was having problems figuring out where the spaces went. I think what happened was it deleted abunch of system files. I was getting popups from "windows File protection" and I couldn't stop it. So, I did a hard shut down and when it rebooted it was missing the hal.dll file.
    on top of that, either the cdrom is going bad or the HD going bad or maybe even a loose connection but when I tried to bootup with the cd it said mountmgr.sys is corrupt or missing. I would restart and then another file was missing or corrupt.
    Thankfully, I have several HD and was able to get the OS installed on one of them and was able to pull off 12 gigs of my kid pictures, videos and the like.
    So, after getting my info saved I checked the disks for errors ran chkdsk and it said that HD was "healthy ". So, I tried again to get the OS on it. First time got a mountmgr.sys file missing or corrupt. I restarted. Second time, had another file that was missing or corrupt. It restared and start to install the os on the third try.
    But, its working now.
    My mother inlaw, who is a super geek, and I was phoning to get advice and to vent got me a 400gig sata drive. Its going to ROCK!!
    yeah, I have a sata2 connection.
    And just purchased 2 gigs pc2 6400 RAM modules!! That will run in dual channel mode, yeah baby!!
    Anyways, sorry for venting and bragging.
    Heath
